Do I have BPU or not?
cheekymonkey
Here is a picture down the exhaust side of the engine. Is that a cat in the middle of a picture? Looks like it to me but would like confirmation.
If it is indeed a cat then I am running 2nd decat only, which is still really loud. Would decatting this one make it even louder?
Does look very Cat like to me mate. And Yes it would be a lot louder with a second decat pipe on there :eyebrows: :D
Yep, thats a stock cat for sure. Removing the first cat on a TT won;t make much difference to the noise level, but it does make the car sound nicer ;)
One thing to to note is that I have a custom exhaust - it's a straight through pipe from cat 1 to the back of the car, no muffler or anything. Would the noise level really not be affected that much?
Also, to go BPU would I definately need to remove it? Am guessing Yes but want to hear your thoughts Mr Simpson.
Yes, you should remove that cat, its not good to have a restriction so close to the turbo with increased boost.
Most aftermarket exhuasts have only one straight through silencer at the back, does yours have any silencer at all?
There is certainly nothing visible under the car, it's just one long pipe with the same diameter all the way up to Cat 1. I am assuming a silencer would be fairly obvious?
