Stonkin Posted April 5, 2007 Author Share Posted April 5, 2007 i'm gona go check the oil Quote Link to comment Share on other sites More sharing options...
Jake Posted April 5, 2007 Share Posted April 5, 2007 What's the cambelt tension like? Check it on the RHS, before the exhaust cam. It sounds like maybe the idle wheel bracket has snapped. Quote Link to comment Share on other sites More sharing options...
Stonkin Posted April 5, 2007 Author Share Posted April 5, 2007 oil is at top marker Quote Link to comment Share on other sites More sharing options...
Stonkin Posted April 5, 2007 Author Share Posted April 5, 2007 Jake, stupid question, but which side is the exhaust cam and i will go chk now mate Quote Link to comment Share on other sites More sharing options...
Class One Posted April 5, 2007 Share Posted April 5, 2007 Turbo side of the engine. Quote Link to comment Share on other sites More sharing options...
Max Headroom Posted April 5, 2007 Share Posted April 5, 2007 Sounded a bit like mine when it was about to go, main bearing Quote Link to comment Share on other sites More sharing options...
Stonkin Posted April 5, 2007 Author Share Posted April 5, 2007 well if i tug the cambelt inbetween the 2 main pulleys under the spark plug cover it moves about 1/2 a cm from lowest to highest. Cant really chk it any other way with the cover on there Quote Link to comment Share on other sites More sharing options...
Jake Posted April 5, 2007 Share Posted April 5, 2007 Jake, stupid question, but which side is the exhaust cam and i will go chk now mate Well, it's the exhaust side innit. Driver's side if you like Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 5, 2007 Share Posted April 5, 2007 Check all the spark plugs are tight. Quote Link to comment Share on other sites More sharing options...
Stonkin Posted April 5, 2007 Author Share Posted April 5, 2007 cheers Jake and Chris. its pitch black out there now, so might have to try again in the morning. I'm just crap with fixing cars Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 5, 2007 Share Posted April 5, 2007 I'd get someone out that knows the cars to look at it. If it IS something serious you could be doing a lot MORE damage just by running it. Quote Link to comment Share on other sites More sharing options...
Stonkin Posted April 5, 2007 Author Share Posted April 5, 2007 yeah thats what worries me Chris. I havent started it since i came home in it. I didnt even hear it whilst driving, was only when i got out of it. I wish i knew what it was. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 5, 2007 Share Posted April 5, 2007 yeah thats what worries me Chris. I havent started it since i came home in it. I didnt even hear it whilst driving, was only when i got out of it. I wish i knew what it was. I suspect it isn't anything too serious, if a bearing had gone so badly it knocked at idle I think you would have the low oil pressure light flickering on when it is hot and idling. I think (hope) you'll find it's something fairly trivial, but best to play it safe. You could see if the noise is worse when you take the oil cap off with it idling. It may splash a tiny bit of oil mist out, don't worry about it. You are basically opening up the cam box for the intake cam, so any sounds from within will be a lot louder. Quote Link to comment Share on other sites More sharing options...
Stonkin Posted April 5, 2007 Author Share Posted April 5, 2007 good thinking Chris, i will try that in the morning. Really appreciate everyone's help, i know its hard helping with a fault like this over video evidence Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted April 5, 2007 Share Posted April 5, 2007 I hope its not to serious for you mate and Chris knows what hes on about so fingers crossed! Quote Link to comment Share on other sites More sharing options...
Stonkin Posted April 5, 2007 Author Share Posted April 5, 2007 yeah me to mate. Someone was looking down on me tonight and laughing to cause this and send a screw through my rear tyre on the same journey home Quote Link to comment Share on other sites More sharing options...
Bobbeh Posted April 5, 2007 Share Posted April 5, 2007 Good luck fella, a car as nice as yours doesnt deserve this Quote Link to comment Share on other sites More sharing options...
Kranz Posted April 5, 2007 Share Posted April 5, 2007 As Chris said, have a listen through the oil filler cap, and also listen all around the head & block with a long screwdriver pressed against your ear (handle end, not sharp end ). If that doesn't sort it give me a shout if you want the oil looking at to determine the cause. I will be able to tell you what component it is by measuring the amount of different metals in the oil. It just needs a small quantity sending off and the results come back a few days later. Quote Link to comment Share on other sites More sharing options...
Stonkin Posted April 5, 2007 Author Share Posted April 5, 2007 Cheers Bobbeh, nice of you to say that. and thanks ki4sup, i will try the screw driver thing and removing filler cap in the morning and post up here. Handy to know you can check oil like that. Quote Link to comment Share on other sites More sharing options...
Kranz Posted April 5, 2007 Share Posted April 5, 2007 Handy to know you can check oil like that. Its definately useful if it saves taking the engine out and dismantling it!! Quote Link to comment Share on other sites More sharing options...
Guest Geneb Posted April 5, 2007 Share Posted April 5, 2007 no chance of it being the viscouis fan? i had a similiar noise like that on an old ford and it was the fan Quote Link to comment Share on other sites More sharing options...
Stonkin Posted April 5, 2007 Author Share Posted April 5, 2007 dont think so mate, its coming from around the right hand cam area, around the oil cap. Gona have another check in daylight in the morning Quote Link to comment Share on other sites More sharing options...
Soop Dogg Posted April 5, 2007 Share Posted April 5, 2007 As Chris says, if the shells had gone you'd very likely lose enough oil pressure to bring on the oil light at idle. It sounds just like a sticking valve to me. (When it releases and pops up to hit the cam) I've heard one that sounded just like that before. As you lift the engine speed, it tends to get less too. Have you had any work done around the top end recently? Quote Link to comment Share on other sites More sharing options...
Stonkin Posted April 5, 2007 Author Share Posted April 5, 2007 no not had anything done mate, other than a full service of every fluid and filter about 2 weeks ago. Never noticed the sound until tonight. Plugs were not touched during service as they were done a while ago. Hope you guys are right. Ruffly what kind of price would i be talking to replace a sticking valve? Quote Link to comment Share on other sites More sharing options...
Jake Posted April 5, 2007 Share Posted April 5, 2007 Ruffly what kind of price would i be talking to replace a sticking valve? You don't want to know. It's a turbos off, head off job - so lots. Quote Link to comment Share on other sites More sharing options...
