Stonkin Posted April 5, 2007 Share Posted April 5, 2007 Could do with some help please peeps. Just got home and noticed my engine is making a knocking noise around the cam area! I took a video on my phone incase anyone has any ideas? Also went to a petrol station on way home and drove over a screw which has ripped through a back tyre! Link to comment Share on other sites More sharing options...
Fifty Posted April 5, 2007 Share Posted April 5, 2007 have you checked the cambelt its sounds like it might have split and is hitting the plug cover? probably complete bollox but doesnt sound good. but doesnt sound metallic either Rich Link to comment Share on other sites More sharing options...
Stonkin Posted April 5, 2007 Author Share Posted April 5, 2007 I'll go and wip the plug cover off mate and have a look Link to comment Share on other sites More sharing options...
grahamc Posted April 5, 2007 Share Posted April 5, 2007 sounds like my engine did... shells... Link to comment Share on other sites More sharing options...
Stonkin Posted April 5, 2007 Author Share Posted April 5, 2007 is it ok to remove the oil cap, as obviously it has to come off to get the plug cover off, engine is red hot right now Link to comment Share on other sites More sharing options...
Fifty Posted April 5, 2007 Share Posted April 5, 2007 yes no probs put it back on to run it Rich Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted April 5, 2007 Share Posted April 5, 2007 is it ok to remove the oil cap, as obviously it has to come off to get the plug cover off, engine is red hot right now yes they'll be no pressure or oil flinging about just dont burn yourself! Link to comment Share on other sites More sharing options...
Stonkin Posted April 5, 2007 Author Share Posted April 5, 2007 cool, back in a mo Link to comment Share on other sites More sharing options...
Homer Posted April 5, 2007 Share Posted April 5, 2007 Also check your crack pulley hasn't seperated. Hope its not the shells... Link to comment Share on other sites More sharing options...
Stonkin Posted April 5, 2007 Author Share Posted April 5, 2007 How do i do that Darryl? Cambelt looks fine. Started it again and the sound seems to come for 3 or 4 seconds then disappear, then comes back again Link to comment Share on other sites More sharing options...
Fifty Posted April 5, 2007 Share Posted April 5, 2007 crnk pulley is the lowest on check its outer ring has not seperated from the inner one Rich Link to comment Share on other sites More sharing options...
Tom Posted April 5, 2007 Share Posted April 5, 2007 does the sound increase with engine speed, couldnt tell from the vid. Link to comment Share on other sites More sharing options...
Stonkin Posted April 5, 2007 Author Share Posted April 5, 2007 Ok, back in a mo, again will try and get a pic, quite of what yet i dont know dont think itdoes Tom no, seems to go away until engine idles again, but its a loud engine and cant hear much anyway really Link to comment Share on other sites More sharing options...
grahamc Posted April 5, 2007 Share Posted April 5, 2007 Also check your crack pulley hasn't seperated. Hope its not the shells... Shells are not that bad... But I suppose a pulley is better! Link to comment Share on other sites More sharing options...
Stonkin Posted April 5, 2007 Author Share Posted April 5, 2007 Do any of these help, its hard to get in there. The sound also doesnt sound like its coming from a pulley area, more like the top of the engine. Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted April 5, 2007 Share Posted April 5, 2007 the noise doesnt sound like a pulley to me. And from those pics the belts look straight. Christian the pulley your after looking for is quite easy to find. Stand infront of the centre of the engine and look straight down to the bottom pulley with the Aux belt on it, if it still looks attached to the centre bit it isnt that. Link to comment Share on other sites More sharing options...
Fifty Posted April 5, 2007 Share Posted April 5, 2007 that all looks OK have you checked your oil level (cold) sorry dont know how to check the shells( big ends) have you tried a long screw driver or piece of wood to your ear along the cam covers to try to locate a loud spot? be careful dont tangle yourself up in something! Rich Link to comment Share on other sites More sharing options...
Stonkin Posted April 5, 2007 Author Share Posted April 5, 2007 oil level should be fine. Just had it serviced 2 weels ago at phoenix, but i will check it once it cools down. whitesupraboy, isnt that pulley the bottom pulley in the bottom pic? Link to comment Share on other sites More sharing options...
Stonkin Posted April 5, 2007 Author Share Posted April 5, 2007 so if i stick a piece of wood against my ear and move it along the cam covers. Fuk me, the neighbours are gone love this i need a fag really does sound like a cam area though, would that fit in with a shell issue? Link to comment Share on other sites More sharing options...
grahamc Posted April 5, 2007 Share Posted April 5, 2007 that all looks OK have you checked your oil level (cold) sorry dont know how to check the shells( big ends) have you tried a long screw driver or piece of wood to your ear along the cam covers to try to locate a loud spot? be careful dont tangle yourself up in something! Rich To check the shells the bottom needs to come off the engine... so not the easiest thing to check. Link to comment Share on other sites More sharing options...
turbonut Posted April 5, 2007 Share Posted April 5, 2007 Could it be a worn big end or main end bearing?? Piston slap ?? Is there an automatic adjuster for the valve clearance, maybe become defective/worn allowing too much clearance? worn or broken valve spring? Hope you sort it, thinkin bout u lolx Link to comment Share on other sites More sharing options...
Stonkin Posted April 5, 2007 Author Share Posted April 5, 2007 Thanks Linda would anyone agree on any of those ideas? not sure if i should drive it or not as i'm a fare distance from phoenix or turbofit. Is there anyone localish that might be able to give an opinion? Link to comment Share on other sites More sharing options...
JamieP Posted April 5, 2007 Share Posted April 5, 2007 That dont sound good, sounds like shell gone, go check the oil level mate. Link to comment Share on other sites More sharing options...
Fifty Posted April 5, 2007 Share Posted April 5, 2007 so if i stick a piece of wood against my ear and move it along the cam covers. Fuk me, the neighbours are gone love this i need a fag really does sound like a cam area though, would that fit in with a shell issue? yes that should amplify the noise and maybe you can locate it better. btw Ive already had 3 fags Rich Link to comment Share on other sites More sharing options...
Homer Posted April 5, 2007 Share Posted April 5, 2007 Thanks Linda would anyone agree on any of those ideas? not sure if i should drive it or not as i'm a fare distance from phoenix or turbofit. Is there anyone localish that might be able to give an opinion? Most are extremely rare on a 2JZ, the shells less so. A decent garage should be able to rule out most, but if its something internal you're looking at a longer garage visit. Both Phoenix and Turbofit offer very reasonable cost pickup service (About £100 from Reading). Link to comment Share on other sites More sharing options...
