Nic Posted April 5, 2007 Share Posted April 5, 2007 Anyone know or can work out, what the compression ratio would be on a 2JZGE engine with a 2mm head gasket fitted? Quote Link to comment Share on other sites More sharing options...
Digsy Posted April 5, 2007 Share Posted April 5, 2007 Yes, if you tell me the current compression ratio and remind me what the bore and stroke is (86x86?) Quote Link to comment Share on other sites More sharing options...
Digsy Posted April 5, 2007 Share Posted April 5, 2007 OK, I got off my arse and used the search button. The only thing I couldn't find 100% was the stock HG thickness, but I'm using 1.2mm. Bore: 86mm Stroke: 86mm CR: 10.5:1 Stock HG thickness: 1.2mm Your additional 0.8mm thicklness raises the compressed volume from 0.0526 to 0.0572 litres, and drops the CR to 9.73:1 Quote Link to comment Share on other sites More sharing options...
Alex Posted April 5, 2007 Share Posted April 5, 2007 What's the drop for an 8.5:1 TT Engine? I thought the stock HG was 1.4...but it's splitting hairs. Quote Link to comment Share on other sites More sharing options...
Digsy Posted April 5, 2007 Share Posted April 5, 2007 What's the drop for an 8.5:1 TT Engine? I thought the stock HG was 1.4...but it's splitting hairs. It would drop it from 8.5 to a gnat's over 8:1 I did that first, before I noticed that Nic wanted data for the GE Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 5, 2007 Share Posted April 5, 2007 Anyone know or can work out, what the compression ratio would be on a 2JZGE engine with a 2mm head gasket fitted? Stock pistons? Overbored? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 5, 2007 Share Posted April 5, 2007 Anyone know or can work out, what the compression ratio would be on a 2JZGE engine with a 2mm head gasket fitted? http://www.csgnetwork.com/compcalc.html Quote Link to comment Share on other sites More sharing options...
Digsy Posted April 5, 2007 Share Posted April 5, 2007 I assumed everything else would be stock. I also assumed that the head gasket hole diameter is that same as the cylinder bore. Quote Link to comment Share on other sites More sharing options...
dandan Posted April 5, 2007 Share Posted April 5, 2007 I think the uninstalled thickness on the GTE HG is 1.6mm. Not sure if the GE is the same. Quote Link to comment Share on other sites More sharing options...
Nic Posted April 6, 2007 Author Share Posted April 6, 2007 Thanks guys Quote Link to comment Share on other sites More sharing options...
