Chris Wilson Posted April 3, 2007 Share Posted April 3, 2007 I want to run a water supply from the house 1 inch bore riser to a piece of additional land we have bought, a distance of some 100 or so metres. I don't want a big flow drop, what sort of diameter pipe should I use (thinking alkathene type pipe here), and where is the cheapest place to order from, with some fittings? Thanks. Quote Link to comment Share on other sites More sharing options...
peter richards Posted April 3, 2007 Share Posted April 3, 2007 hi chris , google pipe fittings supplies in your area , push fit plastic should do the job , as long as the pressure isnt to high . is it going to above or below ground chris as lagging will also be required for the winter time Quote Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted April 3, 2007 Share Posted April 3, 2007 maybe a daft answer but screwfix do shed loads of stuff like this and it gets delivered to ya door Quote Link to comment Share on other sites More sharing options...
Pabs Posted April 3, 2007 Share Posted April 3, 2007 and by the thread title there was me thinking someone wanted to get some kind of warped cover band for the "Village People" together.... Of course, that is NOT the reason why i actually READ the thread....... :S Quote Link to comment Share on other sites More sharing options...
JamieP Posted April 3, 2007 Share Posted April 3, 2007 Depends on the size of the main comining into your property but if you go with 25mm poly you will be safe. Quote Link to comment Share on other sites More sharing options...
Bob Posted April 3, 2007 Share Posted April 3, 2007 20 or 25mm alkathene will be fine Chris (you can buy reducers if need be) - try your local Plumb-base (sp?) for the pipe and fittings; Travis Perkins or other builders merchants proabably sell the stuff but generally at much higher prices. Usually comes in 25 or 50m rolls iirc. If you're running it less than 2' below ground level, then you'll need lagging for it to prevent freezing as well. Quote Link to comment Share on other sites More sharing options...
