Red Light flashing drivers footwell.
Foz
What the hell is this light?!?! Its intermittant and flashed red? Ive no idea what it is. i have a MKIV TT Aerotop.
and yes im a newb and proud! =)
We all start form the same position......tee hee
The only thing the car has got fitted is an clifford xl10 alarm, there is an LED in the dashboard for that though so not sure if its a loose one?
The light flashes when the engines on rather than when the keys are in, i noticed it a few times when i pull up at home in the dark, i look down and theres a glimmer of a red light flashing intermittently until i turn the engine off.
If you guys dont know what it is then im worried, i hope its not some dodgy wiring on a car bomb, maybe an ex of mine....mmmm......tee hee.
It's not linked to the rear illuminated fog light switch is it ?
If your fog light is in the brake cluster and has an lluminated switch under the dashboard it can light up when you brake - sounds odd but it can !
Just a thought...
G
  • 3 weeks later...
