Help Needed!! ... Viscous Fan Hub
Guest Rab88
Guest Rab88
Just been down to the mechanics there to see about an issue with the car...
Right now i'm not getting any hot air to the inside of the car.
The viscous fan at the front of the car seems to vary with revs, which, is obviously to keep the whole engine cool. The fan also does not move freely when the engine is off - when the fan is turned by hand, the whole engine turns over. This has led me to believe that the fan has become deliberately ceased, in order for it to vary with RPM and keep the engine cool... does the engine think it's overheating?? and hence is varying the fan with RPM?
I'm not sure if both issues are linked. The thought was by the mechanic that the viscous fan hub need replaced. And that due to the fan varying with the RPM, the engine cannot heat up properly, and therefore there is no heat to the inside.
OR, is there a problem with the thermostat? I.E, the car thinks it's overheating, therefore ceases the viscous fan to vary with RPM, and therfore there is no heat to the interior?
Any help much appreciated!!!
Rab.
Rab,
I think your mechanic may be right on this.
The viscous bit in the viscous fan can become knackered, so that it's locked up all the time. Sounds to me like that's what has happened to yours.
I would replace that first, and then see if you have issues.
Guest Rab88
Thanx for the help. The coolant temperature sits at half way as normal.
I'll go ahead and replace the hub and then see what other problems remain.
Does anyone know where I could get this from?
Rab
You need to get that changed asap, and dont drive it. I drove my old supra with a locked viscous van (didnt know at the time!) and it vibrated the pulley it is attached to and cracked the waterpump that is on the other side...it was a cambelt off jobby to fix :(
I drove my 93 RZ Auto with a seized fan for over a year. Dude kept nagging me to get it changed and to be fair when I did eventually change it I noticed that the car idled so much better, much smoother.
I'm not sure why you shouldn't use a second hand one though. They either work or they don't. It's not like they fall apart.
Tell that to my Mercedes owning customer with the 980 quid plus painting bonnet, plus new viscous coupling and fan ;) They can seize and go out of balance and break the (relatively thin) shaft. Their inertia is pretty awesome. Given they have a very finite life, and failure can be ludicrously expensive, I'd recommend a new one if budget even 1/2 permits.
Guest Rab88
Just a thought....
As there's possibly a problem with the coolant, or there's an air lock, is it possible that the viscous fan has become deliberatly ceased (and keeping the engine too cool), as the car "thinks" it's going to overheat?
If the coolant problem is fixed, might the fan become unceized?
Suppose i'm just unsure if the car has the capability to cease the fan when it thinks it's going to overheat.
Just a thought....
The fan locks up because the white goo that Jake spoke of, becomes turns more viscous. (or less, I can never remember if high viscosity is runny or thick? I keep getting told, but can never remember - anyway....)
So it's a chemical reaction that the car doesn't really have much of say over.
From your description, yours is knackered and is cooling the car all the time. If you change it, then you'll be able to see if there's still a problem with something else.
