RobEvans Posted March 31, 2007 Share Posted March 31, 2007 Has anyone got one of these BCs??? I have a 1bar restrictor ring and with to hit 1.2 bar with the BC. Could anyone share their settings with me for gain % and set gain, I don't seem to be getting anywhere. Iv tried 30% gain and 1.20 set gain (as advised by evo owner) but its not really running over 1 bar Iv also tried 15% gain and 2.00 set gain, this time I did hit 1.2bar but Iv got a feeling I'm doing something wrong Iv also read that turning the gain up to hi can cause detonation. HELP! Link to comment Share on other sites More sharing options...
mr lover Posted March 31, 2007 Share Posted March 31, 2007 intrested, i am about to fit one of these Link to comment Share on other sites More sharing options...
Homer Posted March 31, 2007 Share Posted March 31, 2007 Can't help with the question, but i'll give you a final warning about your sig (which is now edited) Link to comment Share on other sites More sharing options...
Paul Whiffin Posted March 31, 2007 Share Posted March 31, 2007 Has anyone got one of these BCs??? I have a 1bar restrictor ring and with to hit 1.2 bar with the BC. Could anyone share their settings with me for gain % and set gain, I don't seem to be getting anywhere. Iv tried 30% gain and 1.20 set gain (as advised by evo owner) but its not really running over 1 bar Iv also tried 15% gain and 2.00 set gain, this time I did hit 1.2bar but Iv got a feeling I'm doing something wrong Iv also read that turning the gain up to hi can cause detonation. HELP! Hi Rob, Sounds like your trying to adjust the wrong thing, set would normally be a figure of around 50 approx. The 1.20 bit your trying to adjust sounds to me like the boost limiter? Turn the button on the right to adjust the set, the higher the number the more boost you get, the lower the number the less boost you get. Set the gain at around 20. Make sure the boost limiter is above 1.2 otherwise you'll hit it. Ta Link to comment Share on other sites More sharing options...
RobEvans Posted March 31, 2007 Author Share Posted March 31, 2007 Hi Rob, Sounds like your trying to adjust the wrong thing, set would normally be a figure of around 50 approx. The 1.20 bit your trying to adjust sounds to me like the boost limiter? Turn the button on the right to adjust the set, the higher the number the more boost you get, the lower the number the less boost you get. Set the gain at around 20. Make sure the boost limiter is above 1.2 otherwise you'll hit it. Ta Thanks Paul, I cant get the set above 35 for some reason:( Iv set the limmiter to 1.25 bar to;) Have another play later and I'll post my findings Link to comment Share on other sites More sharing options...
Nic Posted April 1, 2007 Share Posted April 1, 2007 Rob do you have an instruction manual? I've attached a copy in case you don't.682.pdf Link to comment Share on other sites More sharing options...
RobEvans Posted April 1, 2007 Author Share Posted April 1, 2007 I was adjusting the wrong setting. Thanks guys Link to comment Share on other sites More sharing options...
Bob Posted April 1, 2007 Share Posted April 1, 2007 Rob, if it's up and running could you let me know what your settings are, please? Hoping to get mine done soon. Link to comment Share on other sites More sharing options...
DrivingTheDream Posted April 1, 2007 Share Posted April 1, 2007 I need these too. The car is boosting fine to 1.1 but I'd like to know what to set other options to. Link to comment Share on other sites More sharing options...
paul mac Posted April 1, 2007 Share Posted April 1, 2007 i run one of these, read the manual nic has posted and make sure you have the dip switchs right on the back and you cant go wrong Link to comment Share on other sites More sharing options...
RobEvans Posted April 1, 2007 Author Share Posted April 1, 2007 dip switch's? I give up with it now and turned it off, Waste of money! Iv spent £70 it petrol trying to tune it and got nowhere, and accidentally hit 1.4 bar to... that was fun PS And why do I have "needs to read the rules" under my name? Its like something my head teacher would write on my report book at primary school when id been naughty lol Link to comment Share on other sites More sharing options...
paul mac Posted April 2, 2007 Share Posted April 2, 2007 dip switch's? I give up with it now and turned it off, Waste of money! Iv spent £70 it petrol trying to tune it and got nowhere, and accidentally hit 1.4 bar to... that was fun PS And why do I have "needs to read the rules" under my name? Its like something my head teacher would write on my report book at primary school when id been naughty lol ok mate but it runs my 510 rwhp fine, seriously these are the easiest to set up B/C you can buy, if you have not got the rear dip switchs for the wastegate type set it will not work fullstop, if you are still struggling i suggest you take it to a tuner Link to comment Share on other sites More sharing options...
RobEvans Posted April 2, 2007 Author Share Posted April 2, 2007 Yeah I'm going to take it a tuners. Thanks for the advice guys! Iv post my setting to Link to comment Share on other sites More sharing options...
