Hks bov or blitz?
jazz1
Sounds about right mate :D
Under low boost you'll hear the turbo stall where it doesn't release properly (tsk-tsk-tsk sound).
I wouldn't buy another, the cheap as chips XS power one sounds "better" and seems to do the job as well, if not better than tha HKS. It only costs about £40 too.
nope its the greddy 2 row and i tryed but it dont fit all the kit came complete otherwise i would of kept it, il try again tommorow
I know a few local people who have the Greddy 2-row kit and it fits fine over the stock airbox. It is rather tight so might need some adjustment.
i had 2 blitz's both on my old gt4, running only 380bhp on 1.4 bar, they both died in 4 weeks, brand new. Then i tried a sard r2d2, that lasted 5 months, before the spring started weakening, then a bailey, same thing. Ive run a HKS ssqv on my gt4, soarer and now supra and have had no such problems. So thats the only one id ever use. never had a single turbo supra though ;)
all you need is a stronger spring with the boitz which is available here
Blitz Race Spring for Use with Blitz Blow-Off Valve
Part # Bl 14099A
This is a stiffer spring for the Blitz BOV. If your BOV is currently unable to hold all your boost then you should install this spring (takes about 3 minutes).
This spring works on both the Blitz Dual Drive and the older Super Sound BOV.
