Big turbo setups
Guest Supeara
Homer:
Great posting. That price breakdown should be compulsory reading for everyone thinking of going single. It looks very realistic to me, factor in labour and it's a der do, isn't it...?
Thanks Chris, kind of you to say that. The actual cost for me was far, far higher than that. I didn't factor in the cost of hire cars, the travel costs to pick up parts, the garage costs when things went wrong, the delivery charges on many items, the petrol costs for the mapping (to, during and from the location) etc, etc. Not to mention the inconvenience of having it off the road (its my only car). Those would easily be another £2k. I would never consider this again without having another car.
Additionally, the service items carried out before the car is ready for even considering a single conversion would easily reach £3k. Brakes, suspension (Most of it had to be replaced), gearbox, axle etc....
£10k would be an absolute minimum budget for a single conversion, to do it 'properly', you could easily double that.
How much would you say that is costing you Graham? (Not getting into the single vs Hyrids thing, but it'd be good info for 'Supeara')
Single VS hybrid, well thats an ongoing debate... depends what you want!!
Technically have not added it up, as I amk having a lot of additional engine work done by that would not normally be required. Heres the breakdown, as best I can remember:
Hybrids - £300 (2nd hand, still in got nick)
FMIC - £650 +-
HKS cams - £400 including gears
HKS Fuel System - £750 (including walbro fuel pump)
HKS Clutch and flywheel comes from Sam @ TurboFit
LINK ECU - £1500 parts, fitting, mapping
exhaust and induction were already on the car.
At the end of the day, I wanted to go single, but wanted to do it properly, and could not afford both, so went for the hybrids instead and built the complete base, for if I decide to go single. If I am not happy with hybrids, I have a decent setup to move to single turbo very easily. :D
I just dug up my old costings file:
MVP order:
HKS Super Sequential Blow Off Valve, Universal
HKS Super Sequential Blow-Off Valve Flange - Aluminum
HKS Blow-Off Valve Fin Inserts
Field's Harness
HKS Twin Power Ignition Amplifier
HKS Fuel Rail for 1993-98 Supra Twin Turbo
Shipping from MVP motorsports
£850
Boostlogic Turbo kit
£3041 after VAT, duty, and delivery
6* 720cc RC Engineering top feed low imp injectors
£415, 2nd hand
Greddy E-Manage
£295, 2nd hand, used once
Spare fuel pump cage
£35, 2nd hand
Turbo heat blanket
free as compo for delays on delivery
RPS Street Max clutch
£485 + £120 to fit
Fuel kit
£750
Extra fuel components
£112
Wideband O2 sensor, module, and gauge
£190, 2nd hand never used
Gauges and sensors
£120
Exhaust manifold gasket, coolant, and oil filter
£78
Pipework/welding
£90
Misc. VWP stuff
£50
Oil change
£48
Total: £6679
That's a similar number :) Note how much stuff I got 2nd hand as well, driving the price *down* to six and a half grand!
-Ian
