Wheres the Ecu?
jazz1
I'm not sure mate. I *think* electronic ignition and ECU don't usually mean the same thing, although I could be wrong. The ECU has many wires going in/ coming out of it, so if it is the ECU you need to plug it into, you'd need to find out exactly which wire you need to tap into.
What's the gauge do? That should help in figuring out where to connect it to.
