jazz1 Posted March 30, 2007 Share Posted March 30, 2007 i believe the electronic ignition is known as the ecu? right, anyways can someone point out to me where the ecu is please in the engine bay:) Quote Link to comment Share on other sites More sharing options...
DamanC Posted March 30, 2007 Share Posted March 30, 2007 Your ECU is in the passenger footwell. Quote Link to comment Share on other sites More sharing options...
jazz1 Posted March 30, 2007 Author Share Posted March 30, 2007 is it like a little black box when u rip the carpet from the passender side? Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted March 30, 2007 Share Posted March 30, 2007 No, its silver. Quote Link to comment Share on other sites More sharing options...
jazz1 Posted March 30, 2007 Author Share Posted March 30, 2007 ok i will check it tommorow and takes some pics, cheers guys Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted March 30, 2007 Share Posted March 30, 2007 Be sure to pull the carpet all the way back,. or lift it to look quite far back under. My aftermarket ecu was located near the seat mount point. Quote Link to comment Share on other sites More sharing options...
jazz1 Posted March 30, 2007 Author Share Posted March 30, 2007 cheers il check tommorow Quote Link to comment Share on other sites More sharing options...
Nic Posted March 30, 2007 Share Posted March 30, 2007 i believe the electronic ignition is known as the ecu? Jazz the ECU (engine control unit) is the engine computer. Quote Link to comment Share on other sites More sharing options...
grahamc Posted March 30, 2007 Share Posted March 30, 2007 is it like a little black box when u rip the carpet from the passender side? Its has a black plastic cover over the ECU, which is a small silver box. Quote Link to comment Share on other sites More sharing options...
jazz1 Posted March 30, 2007 Author Share Posted March 30, 2007 basically i have this gauge and the green wires says it has to be connected to the electronic ignistion so that must be the ecu right? http://www.mkivsupra.net/vbb/showthread.php?t=104046 Quote Link to comment Share on other sites More sharing options...
Jspec Germany Posted March 30, 2007 Share Posted March 30, 2007 Search button ... Quote Link to comment Share on other sites More sharing options...
stevie_b Posted March 30, 2007 Share Posted March 30, 2007 I'm not sure mate. I *think* electronic ignition and ECU don't usually mean the same thing, although I could be wrong. The ECU has many wires going in/ coming out of it, so if it is the ECU you need to plug it into, you'd need to find out exactly which wire you need to tap into. What's the gauge do? That should help in figuring out where to connect it to. Quote Link to comment Share on other sites More sharing options...
jazz1 Posted March 30, 2007 Author Share Posted March 30, 2007 http://www.mkivsupra.net/vbb/showthread.php?t=104046 there a link to the pics Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted March 30, 2007 Share Posted March 30, 2007 Throw that guage off the top of a large building and into the fires of hell/chavvy saxo/civic and do mankind a favour Quote Link to comment Share on other sites More sharing options...
jazz1 Posted March 30, 2007 Author Share Posted March 30, 2007 lol i cant do that it cost money:( Quote Link to comment Share on other sites More sharing options...
Alex Posted March 30, 2007 Share Posted March 30, 2007 Don't you dare fit that to a Supra! It will want - surprisingly - an RPM feed. Quote Link to comment Share on other sites More sharing options...
jazz1 Posted March 30, 2007 Author Share Posted March 30, 2007 lol:sly: Quote Link to comment Share on other sites More sharing options...
Soop Dogg Posted March 30, 2007 Share Posted March 30, 2007 It will want - surprisingly - an RPM feed. Which is exactly what I told you when you asked this question before! Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted March 30, 2007 Share Posted March 30, 2007 Fires of hell i tell thee, Let it burn in brimstone etc. Or just give it to an impoverished Civic owner Quote Link to comment Share on other sites More sharing options...
Soop Dogg Posted March 30, 2007 Share Posted March 30, 2007 ok then - look at this CLICK It's on plug E10, pin 16 (TACO) Or you could buy a Saxo instead? Quote Link to comment Share on other sites More sharing options...
terribleturner Posted March 30, 2007 Share Posted March 30, 2007 I thought you were selling this Jazz?? Quote Link to comment Share on other sites More sharing options...
Alex Posted March 30, 2007 Share Posted March 30, 2007 I thought you were selling this Jazz?? The CHAV is strong in this one. Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted March 30, 2007 Share Posted March 30, 2007 The CHAV is strong in this one. To the dark side he is drawn? Quote Link to comment Share on other sites More sharing options...
letmeshowyou Posted March 30, 2007 Share Posted March 30, 2007 Jazz, don't do it! If you must, I suggest paying someone to do it - if you're not sure what you're doing you could make yourself quite a mess! Quote Link to comment Share on other sites More sharing options...
jazz1 Posted March 30, 2007 Author Share Posted March 30, 2007 i havent done it il just sell it now, but i spent today painted plastic engine bits:) Quote Link to comment Share on other sites More sharing options...
