Sheefa Posted March 29, 2007 Share Posted March 29, 2007 I get the feeling you don't like N/As which is a pity. However, thanks for the comments. Friendly banter matey - nothing insulting intended! Quote Link to comment Share on other sites More sharing options...
Golddigga Posted March 29, 2007 Author Share Posted March 29, 2007 Sorry, one last point. The N/A VVTi engine - Is this all N/As or just the later ones? Quote Link to comment Share on other sites More sharing options...
Alex Posted March 29, 2007 Share Posted March 29, 2007 Sorry, one last point. The N/A VVTi engine - Is this all N/As or just the later ones? N/A VVTi is post 1999! Quote Link to comment Share on other sites More sharing options...
Kranz Posted March 29, 2007 Share Posted March 29, 2007 For the TT engine. You need to have a valve being pushed 10mm's at TDC for a stock engine to become interference. AFAIK the only cams on the market to do this are the JUN 272 10.8mm lift cams. Obviously if you change the head for a skimmed one you reduce the point at which intereference can happen... At which point any serious engine builder should be checking valve to piston clearance on the cylinder with the piston that has the most stand proud, and calculating the clearance at max designed rpm taking into account rod stretch and valve float...... then determining the timing limits for various gasket thicknesses. Or is that too techy??? Quote Link to comment Share on other sites More sharing options...
Golddigga Posted March 29, 2007 Author Share Posted March 29, 2007 i agree Quote Link to comment Share on other sites More sharing options...
MarkTheBoy Posted March 29, 2007 Share Posted March 29, 2007 Very interesting thread this! Didn't realise that non-interference engines existed... good old toyota... they think of everything!!! Quote Link to comment Share on other sites More sharing options...
Pete Posted March 29, 2007 Share Posted March 29, 2007 As extracted from the Maintenance and Service information from Toyota.... Which was what I linked to in the first place. I dunno, you lot could start and argument in a ......[insert somewhere where it's hard to start an argument] Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted March 29, 2007 Share Posted March 29, 2007 I dunno, you lot could start and argument in a ...... I disagree! Quote Link to comment Share on other sites More sharing options...
Sheefa Posted March 29, 2007 Share Posted March 29, 2007 .......conversation about which came first the chicken or the egg? Good idea Pete. I think the Egg came first. Quote Link to comment Share on other sites More sharing options...
Lucifer Posted March 29, 2007 Share Posted March 29, 2007 TEchnically they both evolved. Quote Link to comment Share on other sites More sharing options...
Pete Posted March 29, 2007 Share Posted March 29, 2007 TEchnically they both evolved. Nope. Eggs. Reptiles laid eggs way before there were any chickens. Quote Link to comment Share on other sites More sharing options...
Lucifer Posted March 29, 2007 Share Posted March 29, 2007 Nope. Eggs. Reptiles laid eggs way before there were any chickens. OK which came first, the protien or the Ammeno Acid? Quote Link to comment Share on other sites More sharing options...
Sheefa Posted March 29, 2007 Share Posted March 29, 2007 Oh really? Well, I'm off home now (thank god!) so I won't get mixed up in this argument. My work here is done As an off-side, I've done a hard days work today. Must of posted a good 40 replies on the forum, browsed various pics and have enjoyed 2 delightful lattes and a pint of Guinness. Happy days. Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted March 29, 2007 Share Posted March 29, 2007 OK which came first, the protien or the Ammeno Acid? Amino....but hey, im just keeping up the trend of disagreeing with folks Quote Link to comment Share on other sites More sharing options...
Pete Posted March 29, 2007 Share Posted March 29, 2007 OK which came first, the protien or the Ammeno Acid? Don't Amino acids form proteins? In which case it must be the amino acid... Which came first the amino acid or the peptide bonds required to attach them to make proteins? Quote Link to comment Share on other sites More sharing options...
Lucifer Posted March 29, 2007 Share Posted March 29, 2007 Don't Amino acids form proteins? In which case it must be the amino acid? {clap} Quote Link to comment Share on other sites More sharing options...
Kranz Posted March 29, 2007 Share Posted March 29, 2007 {clap} No, its cleared up now thanks to the penecillin Quote Link to comment Share on other sites More sharing options...
Pete Posted March 29, 2007 Share Posted March 29, 2007 No, its cleared up now thanks to the penecillin Not any more as an increase in antibiotic resistance has led to a decline in its use since the 1970s. Incidentally the word clap is from the old French word "clapier", meaning "brothel". Quote Link to comment Share on other sites More sharing options...
Lucifer Posted March 29, 2007 Share Posted March 29, 2007 I have a pencil? Any help? Quote Link to comment Share on other sites More sharing options...
Pete Posted March 29, 2007 Share Posted March 29, 2007 I have a pencil? Any help? Is there any lead in it? Quote Link to comment Share on other sites More sharing options...
Tom Posted March 29, 2007 Share Posted March 29, 2007 N/A VVTi is post 1999! Apparently not theres only 1 possible n/a vvti in the country, and I dont think it will be either. Thread, http://www.mkivsupra.net/vbb/showthread.php?t=102869&highlight=vvti Quote Link to comment Share on other sites More sharing options...
turbonut Posted March 29, 2007 Share Posted March 29, 2007 Hi Goldigga If your worried about the immediate state of the belt you can do some easy visual/physical checks: check for wear on the teeth, edge of the belt and any cracking at the root of the teeth, check there's no deterioration of the belt from oil etc which can cause swelling and deterioration of the rubber, and no debris (you will get some build up of muck anyway) Look for crazing on the surface of the belt - caused by friction, also for splits or tears. Belts are usually quiet under normal running conditions - if its whining its tightened up too much, if theres slapping it indicates it could be loose. to check the tension is easy - take the belt between thumb and finger and you should just be able to twist it 45 degrees, no more or less. If the belt is damaged or loose the timing will be out which could result in the pistons and valves making contact which is not good and would mean expensive replacements. It wouldn't hurt to get the belt checked out by a professional if your not sure, then take it from there. Hope all is good, L Quote Link to comment Share on other sites More sharing options...
dr_blackman Posted March 29, 2007 Share Posted March 29, 2007 I wasn't sure on my 1998 n/a about if the cam belt had been done or not even though when i bought the car it only had 34k on the clock, I had it changed for piece of mind earlier this month, saves it going and me being stranded, only cost about £120ish to get done so not worth not doing! Quote Link to comment Share on other sites More sharing options...
ShamelessTT Posted March 29, 2007 Share Posted March 29, 2007 Where can you get these done? im in the west midlands and might wanna get mine checked / replaced just for peice of mind if its not that expensive. Supra TT btw. Quote Link to comment Share on other sites More sharing options...
Pete Posted March 30, 2007 Share Posted March 30, 2007 Where can you get these done? im in the west midlands and might wanna get mine checked / replaced just for peice of mind if its not that expensive. Supra TT btw. See ChrisW details in my sig. Quote Link to comment Share on other sites More sharing options...
