single fitting at last!!!
scott23
hi ya just a few pics of the long awaited project now under way
reworx have started today
kit includes
gt45 etc....
50mm waste gate
fcon ecu
new hks stage 8 racing plugs(nice)
new rad with twin fans
oil cooler
and gear box cooler
greedy 4 row intercooler
ap 6 pot front (355)brakes
and envy rear 4 pot (355)brakes
front and rear anti roll bars
front , centre and rear strut braces
stage 2
greedy inlet
q 45 throttle body
hks injectors
uprated fuel pump
and re-programme
stage 3
water pump
hks ingnition mod and new coil pack
new pulleys and crank pulley
stage 4
hks stroker kit
cams and poss pulleys
new head and gasket
and new auto or modified gear box
uprated hand controls with new drivers lighter seat
ill try topop down and get more pics as they go through the stages
yes thats reworx in hilsea, been a customer for years with my rx7.
if theres any advice on auto upgrades please leave info be very helpful
going to use mostly for track and drag with some road use i hope.
its the same gt45 that dj craig used in the 10sec supra, he recon it was a gooden!!!
cheers guys/gals
ill try keep the pics coming :sly:
first stage will be ready this weekend but cant put on dyno as me rear pistons is rubbing discs so waitin on envy to send brakes and bits.
all parts are here for stage 2 just going to run in for 2-300 miles make sure all seems well,
waiting on stroker kit to arrive which i ordered from nic (good chap)
  • 1 month later...
well hoping end of this week rear brakes will be here so ill find out wat power were running
thanks to gaz at envy for ordering new race head and nic 4 the stroker should b back in work shop with in a month or so
ill post figs this week
Reworx, isnt that the company who are going through some kind of legal battle for screwing RX7 owners ? Not sure which garage it is, but reworx rings a bell. Hope for your sakes its not them!
:( I hope not my supra's going down there to have a EMU fitted and mapped
not sure wat kind of thing is going on i not heard out! hes seems always busy with 8-9 cars there for the both of em fingers crossed.
gone for the hks kit im going to limit it to 7k but work more with the bottomend of the rev range instead.
  • 2 weeks later...
Good luck with the build scott, ive had a gt45 on for a while now now probs.
Not as laggy as i expected, and just keep pulling.
Also i fabbed the boost pipes to go straight down between the engine and chassis, looked abit tight around the inner wing with the pipes and air filter.
