Changing the Fuel Filter
toyotasuprauk
You can also pull the EFI fuses and crank the engine a few times to relieve pressure. There was a step by step guide somewhere.
Careful with that tapered pipe thread connection mine leaked afterwards even though i had it pretty tight.
I am paying someone else to do it, too messy for me! They want me to bring it in on empty. Last time they tried it had lots of fuel in the car and they said it kept pouring out (about 2 litres came out,) and something about one of the pipes being seized in one side of the filter. Hence they have booked me back in and asked for it with no fuel. I wondered if they was an easier way round it but it seems it’s not the nicest of jobs!
as Chris says the union nuts on the filter can be VERY tight so make sure you have good tools and a contingency plan if it all goes pete tong:eyebrows:
And for god's sake don't attempt to solder/braze/weld it if it leaks :blink: :bang:
pmsl best use i've ever seen of that smilie, it should not piss any fuel out whether the tank is full or not tell the numptys to wait about 30-40 minutes to let all the pressure decay before they do it
the thread on the fuel line is metal and the filter is a alloy
the problem is the threaded part of the fuel line doesnt want to free from the filter so you push a wee bit harder and it ruines the thread on the fuel line
make sure you have a 17mm thread tap so you can fix the threads if they bugger up!!!
ive had to deal with this alot at my old work (toyota)
Thanks Jake some good advise.
I know what you mean Sheefa I need to put my new HT leads on. Normally a really quick easy job but on the Supra, oh no need to move the throttle body out the way first!
Nah, a bit of patience, fiddling and a sore back & knees you can get them in without removing that. Same goes for the plugs.:)
You could remove the ashtray and give it a clean :D that's easy.
James, you would think so wouldn't you......but you're wrong!!!
The previous owner has screwed it to the panel surround for some bizarre reason - ask TrickTT he was like 'What the heck?' when he helped me install RLTC! :rolleyes:
It's the same crap job to change the Soarer fuel filter.
Someone who works on a lot of them had this made up
"one end is the same as the original, and the other is a compression joint that is made to connect to the original pipe once the twisted damaged pipe is cut off"
  • 2 weeks later...
I'd say every 30,000 miles. It's VERY unlikely this is anything to do with your problem though.
Thanks Chris.
Just ruling out possibilities. :)
My AEM wideband shows that my AFRs are rich though on stock 440 injectors and I have no idea why or how this can be. The lamba sensor is mounted in the downpipe as near to the turbos as possible for an accurate reading.
Any ideas Chris - faulty sensor maybe?
If you've read my recent post and another you'll see that we've both just fitted the AEM A/F gauge and can now see our A/F ratios.
Running rich at higher boost level than stock appears to be common or even normal with the J spec cars. :)
Are you runnining an increase in boost over stock?
