Sheefa Posted April 10, 2007 Share Posted April 10, 2007 If you've read my recent post and another you'll see that we've both just fitted the AEM A/F gauge and can now see our A/F ratios. Running rich at higher boost level than stock appears to be common or even normal with the J spec cars. Are you runnining an increase in boost over stock? Thanks Merckx mate but mine is actually IDLING Rich at late 12's early 13's! Should be around 14.6-.9 iirc. Just a little concerned that's all. When on boost, running 1.2bar she drops into the nice 10's and 11's Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 10, 2007 Share Posted April 10, 2007 I'd first try a new O2 sensor. I'd also check your wideband gauge against a known good one, freshly calibrated. Link to comment Share on other sites More sharing options...
merckx Posted April 10, 2007 Share Posted April 10, 2007 I'd first try a new O2 sensor. Definately. My car failed the MOT . It was running rich and producing too much CO, the new O2 sensor fixed it. Link to comment Share on other sites More sharing options...
