rovervi Posted March 27, 2007 Share Posted March 27, 2007 Anyone got any good tips ways on how to remove/replace this, got a new one and gonna give it a go at the weekend. Quote Link to comment Share on other sites More sharing options...
M4RK RZ Posted March 27, 2007 Share Posted March 27, 2007 Lift the carpet neer drivers door. - 1 bolt holds it in place mate M10 bolt. Not sure about other end Quote Link to comment Share on other sites More sharing options...
Rob Posted March 27, 2007 Share Posted March 27, 2007 You'll need to remove the door runner trim and kick plate in order to lift the carpet. Quote Link to comment Share on other sites More sharing options...
rovervi Posted March 28, 2007 Author Share Posted March 28, 2007 You'll need to remove the door runner trim and kick plate in order to lift the carpet. took door runner off last night, is it easy to remove the kick plate Quote Link to comment Share on other sites More sharing options...
Lucifer Posted March 28, 2007 Share Posted March 28, 2007 Just pull Quote Link to comment Share on other sites More sharing options...
rovervi Posted March 28, 2007 Author Share Posted March 28, 2007 Just pull cool, just clips then should be easy enough to do this hopefully Quote Link to comment Share on other sites More sharing options...
Rob Posted March 28, 2007 Share Posted March 28, 2007 There's a little push-in clip dead centre of the kick panel, so don't "just pull" or you'll shatter it. Quote Link to comment Share on other sites More sharing options...
Guru Posted March 28, 2007 Share Posted March 28, 2007 Why you removing it? Quote Link to comment Share on other sites More sharing options...
rovervi Posted March 28, 2007 Author Share Posted March 28, 2007 Why you removing it? never knew i was missing boot release in the car as the previous owner must have snapped it off, somebody on the forum made me wise to the fact that there was supposed to be one. Just going to replace that with the new one i have sourced. Thanks for the advice much appreciated Quote Link to comment Share on other sites More sharing options...
rovervi Posted April 1, 2007 Author Share Posted April 1, 2007 Thanks for your info on this fella's i did it yesterday, it took all of about 10 minutes it was a really easy job Thanks again Quote Link to comment Share on other sites More sharing options...
