Timwildman Posted August 1, 2004 Share Posted August 1, 2004 OK here's my dyno results from Billing, All little on the low side, time for some de-cat action I think. Good fuel for 1.1bar apparently http://homepage.ntlworld.com/timwildman/pics/run%20sheet%20boost.JPG http://homepage.ntlworld.com/timwildman/pics/run%20sheet%20hp.JPG http://homepage.ntlworld.com/timwildman/pics/run%20sheet%20AFR.JPG HP vs AFR HP vs Torque boost sorry about the quality, No scanner here. Car is 98, TT, VVTI, triptronic, Engine totally stock Quote Link to comment Share on other sites More sharing options...
Bobbeh Posted August 1, 2004 Share Posted August 1, 2004 That is low.. sure its not an NA Have you had a compression test done? Maybe some hoses need replacing because thats way too low for a TT. I think Milhouse got 300 odd totally stock (but for cat back exhaust) on his run with a J-spec auto Quote Link to comment Share on other sites More sharing options...
Timwildman Posted August 1, 2004 Author Share Posted August 1, 2004 Originally posted by Bobbeh That is low.. sure its not an NA Does need a service, maybe a new air filter will do it Quote Link to comment Share on other sites More sharing options...
Bobbeh Posted August 1, 2004 Share Posted August 1, 2004 Hehe, hopefully its nothing serious.. I was just looking at mine as a comparison, and mine was making more tourque on the first turbo than yours on both, so somethings deffo up. Maybe a split hose or something controlling the boost is limiting things and its not engine/internals related. Quote Link to comment Share on other sites More sharing options...
dandan Posted August 1, 2004 Share Posted August 1, 2004 Maybe, but it was actually make quite reasonable boost for a stock car. What boost did Millhouse's car hit on the dyno, any idea? Fuelling looks a little rich to me although quite consistent - no massive fluctuations as no 2 starts to come on line. Are you sure you are running a stock ecu? A few Jap cars did sneak over with non standard ecu's. Might be worth a look - 2 minute job. Quote Link to comment Share on other sites More sharing options...
Timwildman Posted August 1, 2004 Author Share Posted August 1, 2004 Originally posted by dandan Maybe, but it was actually make quite reasonable boost for a stock car. Are you sure you are running a stock ecu? A few Jap cars did sneak over with non standard ecu's. Might be worth a look - 2 minute job. Yeah boost is good, Pete said about exhaust,.. etc. It does need a service, filter is almost black it's so dirty. should have done it before I went to billing. I'm not sure about ECU, but the car was in uk with 0 miles, so dont think theres any Jap mods there. Quote Link to comment Share on other sites More sharing options...
SimonB Posted August 1, 2004 Share Posted August 1, 2004 I'd change your plugs too Tim, or at least have a look and see what state they're in. There were a couple of puffs of white smoke out the back as you pulled on to the motorway on the way back from Billing, it was fine after that all the way home though. Quote Link to comment Share on other sites More sharing options...
Bobbeh Posted August 1, 2004 Share Posted August 1, 2004 Ah.. blocked/knackered cat possibly?? Quote Link to comment Share on other sites More sharing options...
Syed Shah Posted August 1, 2004 Share Posted August 1, 2004 Originally posted by Bobbeh Ah.. blocked/knackered cat possibly?? That would also give the symptom of lowered boost. I reckon that rich AFR in combo with the hot weather are responsible for the low numbers. What fuel was it running? Quote Link to comment Share on other sites More sharing options...
osso Posted August 1, 2004 Share Posted August 1, 2004 Those dyno results look as crap as mine did at Thors.. and i also have a 1998 VVTi but 6sp Manual.. i've since taken off the stock exhaust and both cats uprated fuel pump and it has made a significant difference. Quote Link to comment Share on other sites More sharing options...
Timwildman Posted August 1, 2004 Author Share Posted August 1, 2004 Originally posted by Syed Shah That would also give the symptom of lowered boost. I reckon that rich AFR in combo with the hot weather are responsible for the low numbers. What fuel was it running? petrol,.... always optimax, lol Quote Link to comment Share on other sites More sharing options...
richy2jz-gte Posted August 1, 2004 Share Posted August 1, 2004 mines poop on optimax always goes loads better with esso super unleaded Quote Link to comment Share on other sites More sharing options...
millhouse Posted August 1, 2004 Share Posted August 1, 2004 Originally posted by Bobbeh I think Milhouse got 300 odd totally stock (but for cat back exhaust) on his run with a J-spec auto Yes Quote Link to comment Share on other sites More sharing options...
millhouse Posted August 1, 2004 Share Posted August 1, 2004 Originally posted by dandan What boost did Millhouse's car hit on the dyno, any idea? 303.5 hp @ 5819 rpm 300.5 ft/lb @ 4213 rpm 0.86 bar / 12.24 psi My results are Here Quote Link to comment Share on other sites More sharing options...
