Disabling the Passenger Air Bag
b.weeks
Apart from just "ripping" the air bag unit out (which I'm considering and just replacing with gauges), is their an easy way to disable the passenger air bag? I'm guessing there's a fuse for it?
(Little-un on the way and you can't have an air bag with a child seat).
When I took my loom over from the VVTi, it had the passenger airbag. I prefered the idea of having a glove box, so I took it out. Bear in the airbag had been de-powered for around 3 days (off the battery) before I even attempted disconnecting it, it is a molex multiplug that holds it in, colour coded yellow.
  • 3 years later...
Guest elitecustombody
not in MKIV, if any component of air bag system is disconnected,none of the airbags will function in the event of collision
