rovervi Posted March 24, 2007 Share Posted March 24, 2007 Hi Just a quick question, whats the easiest place to get a cable from the engine bay through to the inside of the car. Thanks Pete Quote Link to comment Share on other sites More sharing options...
RICHARDA Posted March 24, 2007 Share Posted March 24, 2007 Grommits Quote Link to comment Share on other sites More sharing options...
JamieP Posted March 24, 2007 Share Posted March 24, 2007 Top left corner of the engine bay is a large gromet that feeds down to the drivers footwell, i use a coat hanger though the hole then tape whatever cable i want to pull through to it and pull it through. Quote Link to comment Share on other sites More sharing options...
rovervi Posted March 24, 2007 Author Share Posted March 24, 2007 Top left corner of the engine bay is a large gromet that feeds down to the drivers footwell, i use a coat hanger though the hole then tape whatever cable i want to pull through to it and pull it through. Thanks Jamie Quote Link to comment Share on other sites More sharing options...
Angarak Posted March 24, 2007 Share Posted March 24, 2007 Feed it through the drivers wing into the drivers footwell - you'll have to take out the plastic inner arch liner to do it. Quote Link to comment Share on other sites More sharing options...
colsoop Posted March 24, 2007 Share Posted March 24, 2007 What cable are you running ? Quote Link to comment Share on other sites More sharing options...
jazz1 Posted March 24, 2007 Share Posted March 24, 2007 there also one on the passengers side Quote Link to comment Share on other sites More sharing options...
grahamc Posted March 24, 2007 Share Posted March 24, 2007 there also one on the passengers side for the passenger side one, the wheel arch liner needs to come off so you can get to the grommits. not sure about the drivers side. Quote Link to comment Share on other sites More sharing options...
rovervi Posted March 24, 2007 Author Share Posted March 24, 2007 What cable are you running ? Live for my amp, i would be happy to just get the old stock amp working again but i dont know how to get that going again Cheers Pete Quote Link to comment Share on other sites More sharing options...
Guest mk47 Posted March 24, 2007 Share Posted March 24, 2007 Pete when fitting my amp we found a really good way to route the amp live without having to stretch it across the whole engine bay from the battery to the drivers side. im gonna try find a pic of an engine bay now and will draw out a little diagram the wire then comes straight into the passenger footwell and perfect for you to route it through to the boot under the carpet. Quote Link to comment Share on other sites More sharing options...
Guest mk47 Posted March 24, 2007 Share Posted March 24, 2007 here. unbolt the part circled and behind there is a sort of grommet where a few wires go into, slightly cut the rubber to make it big enough to thread the live wire through and thread it through, the wire then comes inside the car at the top by the passenger footwell get a good grip and pull it through very simple to once you have a look you will see what i mean. its alot easier than going through the side of the wing and moving arch liner etc. (ps had the pic of engine bay on my pc, cant remember whos it is but im sure they wont mind me using it;)) Quote Link to comment Share on other sites More sharing options...
colsoop Posted March 24, 2007 Share Posted March 24, 2007 Live for my amp, i would be happy to just get the old stock amp working again but i dont know how to get that going again Cheers Pete I would go down the passenger side you want the cable to be as short as possible from the battery and it will save on any possible interference issues although unlikely. Quote Link to comment Share on other sites More sharing options...
Guest mk47 Posted March 24, 2007 Share Posted March 24, 2007 I would go down the passenger side you want the cable to be as short as possible from the battery and it will save on any possible interference issues although unlikely. Quote Link to comment Share on other sites More sharing options...
colsoop Posted March 24, 2007 Share Posted March 24, 2007 ?? Quote Link to comment Share on other sites More sharing options...
Guest mk47 Posted March 24, 2007 Share Posted March 24, 2007 ?? its been a long day lol. Quote Link to comment Share on other sites More sharing options...
supra steveo Posted March 24, 2007 Share Posted March 24, 2007 Top left corner of the engine bay is a large gromet that feeds down to the drivers footwell, i use a coat hanger though the hole then tape whatever cable i want to pull through to it and pull it through. a coat hanger ? i just stuck my hand up the back of the dash and pulled it through that gromit is massive ( then again i have little boy hands ) the last time i used a coat hanger was to pas speaker cable through the grommits on the doors and i cut my fingers to bits Quote Link to comment Share on other sites More sharing options...
rovervi Posted April 6, 2007 Author Share Posted April 6, 2007 here. unbolt the part circled and behind there is a sort of grommet where a few wires go into, slightly cut the rubber to make it big enough to thread the live wire through and thread it through, the wire then comes inside the car at the top by the passenger footwell get a good grip and pull it through very simple to once you have a look you will see what i mean. its alot easier than going through the side of the wing and moving arch liner etc. (ps had the pic of engine bay on my pc, cant remember whos it is but im sure they wont mind me using it;)) Did this today, and this one was a piece of cake, Standard sub is now running on a decent Amp and it doesnt sound half bad Quote Link to comment Share on other sites More sharing options...
