pulley problems
supra steveo
Squeaks when the air con is on or off???
Does switching the air con, lights, heated rear screen (& whatever else you have) on make it go away?
What is the condition of the belt?
Does it do it with the engine hot?
It may just be the belt needs replacing?
Christ, no wonder it's loose, you've only got the centre part of the crank pulley, where's the rest of it?
Have a look in your undertray, to see if something like the attached photo is laying there.
You need a new crank pulley fitting, £180-200 part price from Toyota.
whats it supposed to look like?
What i did was take it off pop the rubber off the top of the bearing wash out with wd 40 getting all the lube out, repack with high temp bearing lube put back together back on no more nois :)
Never tried that. May give it a go as maintenance next service. Nice one :D
Ahhh I seeeeee.
As you were then....note to all, use pictures of your own car, not worrysome stuff from other threads.
Indeed, at least have the decency to say it is not a picture of your actual car. :rolleyes:
ohh yeah i forgot to add that bit .......sorry guys
BTW this picture is not off my car :D
Blimey! STILL on the ball Rob.
You'd have to get up pretty early in the morning to catch you out...... Infact you'd have to not go to bed at all :p
Hey, I'm pretty sharp, you know the trojan horse?
I rode that horse.
