brake bleeding help!!!!
ukApache
Yeah definately need 2 people, I was helping bleed the brakes of a GT4 fairly recently, it took forever and the problem was the ABS unit.
I suspected it might have something to do with the ABS because I've only ever bled the brakes on cars without ABS and never had any problems.
do you mind me asking how you got around the problem? Did you use any special technique?
Thanks.
sometimes you can miss the obvious ,as the calipers have been removed and overhauled,have they been refitted correctly?,they can be fitted upside down ie left to right and vice versa so the bleed nipple is over the caliper in stead of under.
this means that the air trapped in the lower part of the caliper cannot be bled as the nipple in above it.
could be one of those doh! moments we all have
worth checking..
I honestly can't say with 100% confidence as I was in the car at the time and couldnt see what he was doing, i'm sure someone else will be along shortly that can help, well hopefully :)
Thanks anyway :)
worth checking..
I checked and it turns out I have 2 right calipers (assuming that the bleed nipple should be at the top)??? :wtf: which means that the one on the left side of the car (off-side) IS fitted upside down (bleed nipple at the bottom). I cant believe I didn't notice this before!
Is it actually possible to bleed this caliper? maybe remove it from the car & turn it upside down (the right way around) when bleeding then fit it back to the car? or do I have to replace it with a correct left side one :(
Thanks again guys ;)
Finally I've got working brakes!!!! :D
I took the off-side caliper off the bracket, turned it upside down so the bleed nipple was facing up and bled it as normal. Put it back together and the pedal is firm once again!!
Thanks jagman for your suggestion! without it I probably would have pumped another ~5L through the system (as I was told to do by a local mechanic). Also thanks to everyone else who gave advice on this, I'm very grateful ;)
I hope soon I get the chance to help others on this forum :)
