EManage Ultimate help
Kranz
I'm browsing the software, messing about and seeing what's what. Problem is I can't view the maps fully as they don't autofit onto the screen properly.
For example I can't seee the bottom line of this one no matter what I try!
Anyone else had this?? Any ideas how to sort it??
Steve, can you try and adjust your screen resolution buddy and see if that helps? Head to Properties (right click on desktop) and 'settings' and try a few different screen resolutions there, 600x800, 1280x720 etc etc. That 'may' help.
Failing that, reinstall and see if you have any luck. What graphics card to do have to? Does that have any display property options mate?
Or, perhaps have a look through here buddy and post something up: ?
http://www.emanageforums.com/forums/index.php?
Greg
i did this with my blue emanage. to fix i went to view / map size / large. not sure on ultimate tho
HTH
It aint got that Ryan, but thanks for the try!
Will try some of the other suggestions chaps. Thanks!
