Tricky-Ricky Posted March 23, 2007 Share Posted March 23, 2007 Had a bit of a play with am M3 on my local track, and was a little peeved that he kept up with me, but what i did notice was that over a slightly uneven surface and more noticeable under high speed braking, the car tends to pull slightly to one side, does this sound like a worn bush? although i checked recently and could find none? shocks are new, and the brakes are good Link to comment Share on other sites More sharing options...
merckx Posted March 23, 2007 Share Posted March 23, 2007 Misaligned suspension? Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted March 23, 2007 Author Share Posted March 23, 2007 Good point, i should have mentioned that it also tends to wonder at high speed on an uneven surface, with and without braking,but breaking make it worse, think i will start looking for a good alignment place in the South East, if one exists? Link to comment Share on other sites More sharing options...
Kranz Posted March 24, 2007 Share Posted March 24, 2007 Good point, i should have mentioned that it also tends to wonder at high speed on an uneven surface, with and without braking,but breaking make it worse, think i will start looking for a good alignment place in the South East, if one exists? Discount Tyres Direct in Worthing..... Costs though. Full suspension setup to whatever figures you want (I have Lance W's) £215 if each has to be adjusted (they charge per adjustment). Spot on when its done though Link to comment Share on other sites More sharing options...
Sheefa Posted March 24, 2007 Share Posted March 24, 2007 Or CW for good measure and reasonable prices Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted March 24, 2007 Author Share Posted March 24, 2007 Discount Tyres Direct in Worthing..... Costs though. Full suspension setup to whatever figures you want (I have Lance W's) £215 if each has to be adjusted (they charge per adjustment). Spot on when its done though Your not kidding! i thought about £80 to £100, Chris may be good Greg, but by the time i added petrol to the equation it wouldn't be cheap;) Link to comment Share on other sites More sharing options...
