Ryan.G Posted March 22, 2007 Share Posted March 22, 2007 Hi Right so i have just got a emanage blue and looking through the software of it to get used to it. Now i have some knowledge of tuning powerfc's but the table layouts on the emanage is very different. Now i take it that you guys use the airflow table to take out fuel as the Addinj table wont allow you to remove duty. Now on the powerfc you view the boost vs rpm to make changes to the fuelling but on the emanage you have throttle vs rpm. Is there any way of changing the throttle axis to boost pressure like on the addinj table. As this would make things so much easier. Now i have the greddy boost sensor but unsure on how to plot it in the airflow table. Anyone done this?? THanks Quote Link to comment Share on other sites More sharing options...
SimonR Posted March 30, 2007 Share Posted March 30, 2007 I've just had a play and I can't see a way of doing this. Do you have a reason for not wanting to do it this way? Just interested you understand. Quote Link to comment Share on other sites More sharing options...
SimonB Posted March 30, 2007 Share Posted March 30, 2007 If you take more airflow out than you need across the board on the airflow adjustment, you can then add it back in using the injector adjustment, which is boost based. Then you can use the airflow table to make throttle related changes too. Quote Link to comment Share on other sites More sharing options...
