Guru Posted March 21, 2007 Share Posted March 21, 2007 As pictured. Know what it will do if anything? I have a small kink in it so am wondering if it should affect anything Link to comment Share on other sites More sharing options...
RobAce Posted March 21, 2007 Share Posted March 21, 2007 yep it joins them 2 pipes together Link to comment Share on other sites More sharing options...
Guru Posted March 21, 2007 Author Share Posted March 21, 2007 yep it joins them 2 pipes together LOL I can see that but what is there now may not be what was there as stock Link to comment Share on other sites More sharing options...
Ric Posted March 21, 2007 Share Posted March 21, 2007 i cant remember seeing that on mine Link to comment Share on other sites More sharing options...
colsoop Posted March 21, 2007 Share Posted March 21, 2007 Technical FAQ http://www.mkivsupra.net/vbb/showthread.php?t=35926 Link to comment Share on other sites More sharing options...
Steviekid Posted March 21, 2007 Share Posted March 21, 2007 As pictured. Know what it will do if anything? I have a small kink in it so am wondering if it should affect anything Did you do that? The EGBV VSV has been bypassed meaning the EGBV will never open. This means your second turbo will never be prespooled and will be "shocked" into use every time it comes online. Which isn't good for it. Are you running in parallel? Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted March 21, 2007 Share Posted March 21, 2007 I have done this in my TTC setup,so that could be the reason,in fact i will be eliminating just about all my hoses and VSVs soon. Link to comment Share on other sites More sharing options...
Steviekid Posted March 21, 2007 Share Posted March 21, 2007 I have done this in my TTC setup,so that could be the reason,in fact i will be eliminating just about all my hoses and VSVs soon. From the first pic you can make out the IACV VSV isn't bypassed so unless it's mechanically wired open or electrically converted the car's running in sequential. In TTC mode the EGBV is redundant anyway so there's no need to bypass it. The only reason I can think of for bypassing the EGBV VSV is to increase the boost created by turbo 1 (at the expense of turbo 2). Link to comment Share on other sites More sharing options...
Angarak Posted March 22, 2007 Share Posted March 22, 2007 Interesting, my plumbing looks nothing like that, presumably due to my boost controller (which came with the car)....Im running in sequential mode. Link to comment Share on other sites More sharing options...
Steviekid Posted March 22, 2007 Share Posted March 22, 2007 Interesting, my plumbing looks nothing like that, presumably due to my boost controller (which came with the car)....Im running in sequential mode. Your boost controller will be plumbed in down at the wastegate VSV. Your EGBV VSV pipework should be as standard. But in black! Link to comment Share on other sites More sharing options...
Guru Posted March 22, 2007 Author Share Posted March 22, 2007 From the first pic you can make out the IACV VSV isn't bypassed so unless it's mechanically wired open or electrically converted the car's running in sequential. In TTC mode the EGBV is redundant anyway so there's no need to bypass it. The only reason I can think of for bypassing the EGBV VSV is to increase the boost created by turbo 1 (at the expense of turbo 2). I am thinking this is correct. An ex-trader (no names) I visited once said he had done a popular mod which saw my first turbo see 1.1-1.2 bar of boost. I did notice that there was less of an jump to turbo #2. I also see turbo #2 hitting in slightly later than normal. Would this be damaging to the tubbies at all? Your boost controller will be plumbed in down at the wastegate VSV. Your EGBV VSV pipework should be as standard. http://www.mkivsupra.net/vbb/attachment.php?attachmentid=13935&d=1112558800 But in black! Thanks for that. Can't quite make out where things go exactly but it's definitely different. Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 22, 2007 Share Posted March 22, 2007 I don't like it, but a lot of people claim to prefer the power delivery. If it was mine I'd return to stock plumbing and use a restrictor and no boost controller at all, but it's not mine.... Link to comment Share on other sites More sharing options...
Guru Posted March 22, 2007 Author Share Posted March 22, 2007 I don't like it, but a lot of people claim to prefer the power delivery. If it was mine I'd return to stock plumbing and use a restrictor and no boost controller at all, but it's not mine.... TBH I don't like what its doing so I will be turning it back. I have one of your restrictor rings already and use the PFC as a boost controller. What do I need to return it back to stock plumbing as I have not seen it before? I will also check the rest of the non-stock silicon tubing for other 'mods' they did. Would this mod have affected the life of tubby #2 Chris? Link to comment Share on other sites More sharing options...
Steviekid Posted March 22, 2007 Share Posted March 22, 2007 What do I need to return it back to stock plumbing as I have not seen it before? Just take the blue hose off and connect the two U-shaped black hoses to corresponding pipes. Would this mod have affected the life of tubby #2 Possibly. Whenever it's come online it's gone from seeing no gas to full gas flow in an instant. Link to comment Share on other sites More sharing options...
Angarak Posted March 22, 2007 Share Posted March 22, 2007 Your boost controller will be plumbed in down at the wastegate VSV. Your EGBV VSV pipework should be as standard. [qimg]http://www.mkivsupra.net/vbb/attachment.php?attachmentid=13935&d=1112558800[/qimg] But in black! Thanks for the link mate, but my plumbing is still different from the setup you have linked to. I've attached some pics, hopefully I've named everything correctly (my knowledge is limited): http://mooch.pwp.blueyonder.co.uk/supra/plumbing/supra_plumbing_1.jpg I can confirm that this is my boost gauge pressor sensor. http://mooch.pwp.blueyonder.co.uk/supra/plumbing/supra_plumbing_2.jpg If anyone would take the time to explain to me how that works I'd be very grateful. My main concern is that its safe and not shocking my #2 turbo (it doesnt feel like it). If the installation instructions for the boost controller are required to work out why its plumbed like that, I have uploaded a copy here (PDF File). Also, sorry for hijacking the thread Guru....but it got me thinking Cheers Simon Link to comment Share on other sites More sharing options...
Ian C Posted March 22, 2007 Share Posted March 22, 2007 I think that looks more complex than it really is. Your boost control hoses appear to be plumbed in normally, but that actuator is in such a place that the hoses need to be rather long. And the feed to the pressure tank is probably a byproduct of the installation method rather than anything particularly "trick". Also I think you've got the #1 turbo mod as well, that's the blocked off pipe stuff. I can't make out too much detail though. -Ian Link to comment Share on other sites More sharing options...
Guru Posted March 23, 2007 Author Share Posted March 23, 2007 Where can I pick these stock pipes up from? I doubt there will be any second hand one lying around surely? Traders Link to comment Share on other sites More sharing options...
Steviekid Posted March 23, 2007 Share Posted March 23, 2007 Where can I pick these stock pipes up from? To connect the EGBV back up? They're right there in your pictures but not connected to anything! Link to comment Share on other sites More sharing options...
Guru Posted March 24, 2007 Author Share Posted March 24, 2007 Ahhh that would explain it. I took those pics in the garage so couldn't see much! Link to comment Share on other sites More sharing options...
