*** FREE *** seat cushions and trim
stevie_b
There's been no buyer interest in these items, so I'll let these go for the sum of £0.00 to the first person who turns up wanting them. I live in Basingstoke BTW.
If not, they'll go into landfill.
Here's the threads:
http://www.mkivsupra.net/vbb/showthread.php?t=99208 (front seat cushions, cloth pre-facelift)
http://www.mkivsupra.net/vbb/showthread.php?t=94542 (plastic trim for front seats, not every piece present though)
I wouldnt mind just the passanger seat cover it zips off :)
Do you want the seat back's cover or the seat base (the bit where your arse goes!), or both? It looks like the seat base cover is held on by plastic clips (dead easy to remove), and some metal clips (hog rings, I think they're called, which I can snip off).
The seat back cover looks a bit more tricky to remove. It looks like the "kind-of-separate" headrest that the pre-facelift seats have, holds the cover in place as well as the zips down the back. I couldn't see how to remove the headrest to free the cover. Markiemark's coming to get the seats tonight (minus passenger covers, if I can get them off), so if you could reply ASAP today that would be great.
Guest blueangel
the cover is hog ringed again and the headrest comes off via two normal headrest clips but they in side rather than on top
Wow. It's a pain in the arse to get the covers off the seats. I started with the base bit, and took off all the hog rings and clips that I could see. At that point, I thought I could just peel off the cloth cover. But no, there's a few more that attach the foam to the cloth on the underside! I can't even see some of them! And I still can't figure out how the headrest clip works on the upright part. I can see the clip on the side, but it doesn't seem to move in any direction.
I might need to give the lot to Mark (who's popping round shortly), and ask that he takes off the covers and sends them to you.
