R3DG3CKO ROB Posted March 20, 2007 Share Posted March 20, 2007 Went to top the car up with V power this morning (to get some more top trumps) and the outer hatch won't open... I'm pulling the lever next to the boot release but nothings happening... I've got 3/4 of a tank left so I'm ok for a few days but I'm gonna be dry by the weekend... Has anyone else had this problem? Any Suggestions? Quote Link to comment Share on other sites More sharing options...
Kranz Posted March 20, 2007 Share Posted March 20, 2007 Cable has probably jammed a bit, stretched or the cold weather is making it difficult to open on the lock side (or all 3!!). Try getting someone to push gently on the flap while you hold the release lever open, then while still holding the release lever open prise the flap out with fingers??? Or get it into somewhere warm?? Or both??? Once open treat it all to a good dose of WD40 then spray grease Quote Link to comment Share on other sites More sharing options...
R3DG3CKO ROB Posted March 20, 2007 Author Share Posted March 20, 2007 Yeah, two person approach, that's my plan - it's really not that cold so I'm guessing that the cable has stretched as there is some resistance, just not enough... anyone know how easy it is to replace/repair the cable? Quote Link to comment Share on other sites More sharing options...
Paul Posted March 20, 2007 Share Posted March 20, 2007 Also had this problem with another Toyota (not Supra). There was a small stip of spring steel that is used to spring the flap out, the cable only pulls back a latch. The spring part had come away so the flap stays put when releasing it rather than springing away to an open position. Not sure if there is the same set up on the Supra or if the spring is located around the hinge area? Worth a look anyway mate;) Paul Quote Link to comment Share on other sites More sharing options...
Bob Posted March 21, 2007 Share Posted March 21, 2007 I had this and as Paul says, it's probably the spring plate. Get some to prise it open while you pull the latch. On mine, I just had to bend the spring steel out a bit more so it had enough 'spring' to push the cover out Quote Link to comment Share on other sites More sharing options...
R3DG3CKO ROB Posted March 22, 2007 Author Share Posted March 22, 2007 I had a go at pushing the hatch while pullling the lever yesterday (I've got really long arms) and it worked... Tried the lever again this morning and it's working fine now... very strange Quote Link to comment Share on other sites More sharing options...
