Best mod I've done for ages
Robbie
Replacing the boot rubbers.
It was a pain in arse to get the screws out, but boy oh boy does it make the car seem better:)
I also fitted a new fan belt using a 14 mm socket and driver on the pulley nut. Took all of 3 mins to do!
I ended up having to cut across the screw heads with a hack saw to make a new slot. Then they eventually turned
When you get squeaks and rattle in the car your overall confidence when driving can be reduced. Its seems odd but a smoother sounding car can make you relax a little more maybe, letting you concentrate on driving more!:) :search:
Makes sense I suppose! so is perished boot rubbers a main cause of noise from the rear??
It was for me!
Before this I'd tried tightening up all the plastic panels, boot tools, spare tyre etc all to no avail.
