Onelife Nofear Posted July 27, 2004 Share Posted July 27, 2004 I just had the unfortunate event of one of my turbos dying :-(. I am looking at getting replacement hybrid turbos. But in-order to get the best out of these what other engine mods would i need( or would benefit from). At min i just have a induction kit and Blitz NUR SPEC R exhaust still with one cat in until MOT later this Month ;-) And before you ask i did do a search but couldnt find anything concrete just what people already have so if there is a string to a past posting that would be great to :-) cheers stew Quote Link to comment Share on other sites More sharing options...
Supragal Posted July 27, 2004 Share Posted July 27, 2004 presuming jspec car, off the top of my head- FMIC, 550 (at least) injectors, afc or emanage, uprated fuel pump I/others will add to this I'm sure... Quote Link to comment Share on other sites More sharing options...
Onelife Nofear Posted July 27, 2004 Author Share Posted July 27, 2004 cheers Yeah it is a Jspec, and i thought i would need injectors but wasnt sure, and FMIC surely thats a luxury?? isnt it Quote Link to comment Share on other sites More sharing options...
Supragal Posted July 27, 2004 Share Posted July 27, 2004 it all depends on what hybrids you're talking about- some people run them on pretty much stock everything but personally I wouldn't... Uprated IC at least. Quote Link to comment Share on other sites More sharing options...
heckler Posted July 27, 2004 Share Posted July 27, 2004 Originally posted by Onelife Nofear cheers Yeah it is a Jspec, and i thought i would need injectors but wasnt sure, and FMIC surely thats a luxury?? isnt it injectors arent "that" important, but at least an FSE - I have an FSE and 550cc Injectors just to make sure, and a Fuel pump is deffo reccomended. No reason to change the SMIC for a FMIC - IF your SMIC is in good shape, saying that I did change mine cos mine was erm... battered slightly Oh, btw I have stage 3 hybrids/fmic/fse/550 injectors/e-manage (to be fitted) Hope this is of some help to ya. Quote Link to comment Share on other sites More sharing options...
womble Posted July 27, 2004 Share Posted July 27, 2004 Go for a full de-cat (big improvement on it's own ) bigger injectors with a Walbro / U.K pump a fuel cut cutter and a good old fashioned bleed valve. You'll almost certainly also need a restrictor ring to stop overboosting but assuming (as earlier mentioned) that your stock intercooler is in ok condition (U.K cars intercoolers tend to be in much worse nick than Jap ones due to the salting of our roads ) then it should be just fine. Oh and whilst your at it you may want to check out the many threads on induction kits on here, the general view tends to be that they don't filter as well as the stock pannel filter and that they pull in more warm air (a BIG no no) too. Out of interest who would you be thinking of using to do your hybrids ?, there've been a few failures (q well documented on here somewhere) of them lately so I'd pick carefully if I were you. I used Turbo Technics (after one of the so called tuners on here never returned any of my calls ) and they were good to deal with and I'm more than happy with mine. If you do a search of McCannys posts you'll find out what he thought of them too having driven the car, good luck mate. Quote Link to comment Share on other sites More sharing options...
SimonB Posted July 27, 2004 Share Posted July 27, 2004 With uprated injectors and/or fuel pressure regulator you will also need a fuel computer of some sort. Options are a stand-alone ECU, SAFC or Greddy Emanage. The Emanage is the one to go for IMHO. Plenty of info on here about it. You may not need a restrictor ring with hybrids as some have enlarged wastegates. Also worth saying that all of these suggested upgrades assume you are going to run higher than standard boost. There's nothing to stop you running standard boost to start with until you sort other stuff out. Personally I would be worried about det with hybrids and a standard intercooler. I would want a FMIC and/or water injection. Quote Link to comment Share on other sites More sharing options...
Supragal Posted July 27, 2004 Share Posted July 27, 2004 he did say he already had an induction kit...? be careful of the turbo "staging" as theres no official description of what this means across the board AFAIK, and last time I asked on here that was agreed with. Of course you could be talking about going BIG twin As I say, some people run hybrids on stock everything else so it's up to you really. I always play safe. I figure if you're messing about with something that Toyota invested loads of time and money into getting right if you're gonna take it apart and change bits, you should keep it all in line as much as poss with equivalent bits to support the changes. If that makes sense Quote Link to comment Share on other sites More sharing options...
Jake Posted July 27, 2004 Share Posted July 27, 2004 Originally posted by Supragal I figure if you're messing about with something that Toyota invested loads of time and money into getting right if you're gonna take it apart and change bits, don't mess about keeping it all in line as much as poss with equivalent bits to support the changes. If that makes sense I honestly didn't understand it. I think I got the gist of it though. Quote Link to comment Share on other sites More sharing options...
Jake Posted July 27, 2004 Share Posted July 27, 2004 Originally posted by Onelife Nofear FMIC surely thats a luxury?? isnt it Apparently there are 600bhp Supras in the states still using the stock side mounted IC without any problems. Originally posted by heckler injectors arent "that" important, but at least an FSE Ooooo, controversial. Some might disagree with both those points mate. Quote Link to comment Share on other sites More sharing options...
heckler Posted July 27, 2004 Share Posted July 27, 2004 injectors arent "that" important, but at least an FSE fair enough - but at the mo, I'm running 1.3 - 1.4 bar with an FSE and pump with no probs, no det, nothing... but saying that I have 550's and a E-Manage to go on... Quote Link to comment Share on other sites More sharing options...
Onelife Nofear Posted July 28, 2004 Author Share Posted July 28, 2004 Excellent thanks for the help, to be honest i thought i might need bigger injectors and a pump. The Hybrids will be from Turbo Technics me thinks, they seem cool guys up there and read some good reviews of them. Most likely have a look at my side mount IC tonight lol see what shape its in. But might do it in stages like suggested and run on normal boost until everythings in place. And I am deff gonna have a full decat just soon as i get my MOT out the way lol cheers stew Quote Link to comment Share on other sites More sharing options...
Darren Posted July 28, 2004 Share Posted July 28, 2004 Your SMIC is ok depending on how high boost you want to run and how old it is and its condition... You can run Hybrids with no mods at all but when you start upping the boost you need other supporting parts as mentioned previously by the other guys... Quote Link to comment Share on other sites More sharing options...
Supragal Posted July 28, 2004 Share Posted July 28, 2004 Originally posted by Jake I honestly didn't understand it. I think I got the gist of it though. agreed. what i typed wasn't at all what i meant- edited to make sense!! Quote Link to comment Share on other sites More sharing options...
