Nic Posted April 11, 2007 Share Posted April 11, 2007 If there are 5 or more members that are interested in buying one of these Greddy Spec M intercoolers, then I can organise another group buy if you want. Link to comment Share on other sites More sharing options...
Nic Posted April 11, 2007 Share Posted April 11, 2007 Would this uphold on say a PHR Stage 1(GT60) running 1.6 bar? Want a small fmic to reduce lag...got a toyo one just now, does the job but woud like a new greddy one when I go single in 5months...its either this or the 3 core...any suggestions? If running 1.6bar I would go for the 3 row Greddy instead, give me a shout if you want details. Link to comment Share on other sites More sharing options...
Andy Supra Posted April 11, 2007 Share Posted April 11, 2007 Does anyone have a pic of the kit before fitting they could post? It was only this morning I deleted mine pics of it out the box before fitting off my photobucket account. I did a post and pics when I got mine about it but pics are gone now typical Link to comment Share on other sites More sharing options...
Mas Posted April 11, 2007 Author Share Posted April 11, 2007 mine didnt require any modifications to the stock box doesn't show clearly whether you had to modify back of the box or not, but if you haven't then its a surprise as I had to, so says Cable !!! and I think this kit is the easiest to fit out of all the other fmic's as it has every single bit needed for fitting, although still didn't make me go for it and I asked Mark to fit mine I think its a bargain for the price Nic supplies these so well recommended to anyone Link to comment Share on other sites More sharing options...
wez_p Posted April 11, 2007 Share Posted April 11, 2007 If there are 5 or more members that are interested in buying one of these Greddy Spec M intercoolers, then I can organise another group buy if you want. i'm definitely interested Nic but don't fancy the wait for weeks, what's the current lead time & prices? Link to comment Share on other sites More sharing options...
Homer Posted April 11, 2007 Share Posted April 11, 2007 doesn't show clearly whether you had to modify back of the box or not, but if you haven't then its a surprise as I had to, so says Cable !!! It should be a straight fit as the kit is designed to work with the stock airbox in place. I've fitted two Greddy 2 rows and a 3 row and though it takes a bit of playing around, they do fit without having to modify anything. I'm sure Jazz will confirm it just takes a bit of fidling to get it to work. Link to comment Share on other sites More sharing options...
Cable Posted April 11, 2007 Share Posted April 11, 2007 It should be a straight fit as the kit is designed to work with the stock airbox in place. I've fitted two Greddy 2 rows and a 3 row and though it takes a bit of playing around, they do fit without having to modify anything. I'm sure Jazz will confirm it just takes a bit of fidling to get it to work. Hmmmm strange... there was no way it would go on without the mod on the airbox. My brother had the same problem when he had his fitted at Phoenix. Link to comment Share on other sites More sharing options...
jazz1 Posted April 11, 2007 Share Posted April 11, 2007 here you go no midfications done on my stock box, thanks to homer who said it will fit and he was correct, you just need to fiddle with the pipe Link to comment Share on other sites More sharing options...
Andy Supra Posted April 12, 2007 Share Posted April 12, 2007 Does anyone have a pic of the kit before fitting they could post? Ah ha founds pics of the FMIC for you before it's fitted... Link to comment Share on other sites More sharing options...
Nic Posted April 12, 2007 Share Posted April 12, 2007 Ah ha founds pics of the FMIC for you before it's fitted... That's great thanks Andy Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted April 12, 2007 Share Posted April 12, 2007 So whats the price on those Nic? Link to comment Share on other sites More sharing options...
supRo Posted April 12, 2007 Share Posted April 12, 2007 I had the same issue when trying to fit a stock air box but the Greddy pipe was fouling it. I guess it's the angle of the pipe inside the wing that you have to fiddle about with? Link to comment Share on other sites More sharing options...
Nic Posted April 12, 2007 Share Posted April 12, 2007 So whats the price on those Nic? 12010448 GREDDY Spec-M - 2 Row FMIC = £372 including airmail to UK Link to comment Share on other sites More sharing options...
R3DG3CKO ROB Posted April 12, 2007 Share Posted April 12, 2007 Looks really awesome Mas - well done Link to comment Share on other sites More sharing options...
DamanC Posted April 14, 2007 Share Posted April 14, 2007 well you can do it yourself its piss easy to do, go on the greddy website and download the english version instruction manuals thats what i did, looking at the jap manuals it looks complicated Any links to this Jazz, i cant seem to find it Link to comment Share on other sites More sharing options...
DamanC Posted April 14, 2007 Share Posted April 14, 2007 Any links to this Jazz, i cant seem to find it Im a tit, found it here http://www.greddy.com/img/PHP/products/pdf/765.pdf Link to comment Share on other sites More sharing options...
wez_p Posted April 23, 2007 Share Posted April 23, 2007 here you go no midfications done on my stock box, thanks to homer who said it will fit and he was correct, you just need to fiddle with the pipe Im a tit, found it here http://www.greddy.com/img/PHP/products/pdf/765.pdf is this definitely the right set of instructions chaps? it refers to cutting some sections out of the body & other parts which i thought wasn't necessary for this kit? Link to comment Share on other sites More sharing options...
Gerry Posted April 23, 2007 Share Posted April 23, 2007 No issues with it fitting behind a VeilSide nose is there ?? Cheers G Link to comment Share on other sites More sharing options...
DamanC Posted April 23, 2007 Share Posted April 23, 2007 is this definitely the right set of instructions chaps? it refers to cutting some sections out of the body & other parts which i thought wasn't necessary for this kit? You need to chop up your splash gauards and arch liner slightly. It also says to chop a little off the body......there is no need to do this. Careful thou as the english version is not the same as the jap one, you need to follow the jap one and use the uk one for help. (different fittement, i crapped myself when the uk one had a diagram of 2 brackets at the top) Hardest part fitting the kit was the pipe over my apexi induction kit. Its like a jigsaw puzzle! I got there in the end Should fit behind a vielside, the inside may need modding, i dont know. Fits behind a stock bumper thou http://img411.imageshack.us/img411/2095/img0134webgf4.jpg Link to comment Share on other sites More sharing options...
wez_p Posted April 23, 2007 Share Posted April 23, 2007 nicely done cheers Daman, going to give it a go one of the upcoming weekends hopefully, can't wait Link to comment Share on other sites More sharing options...
