2jzhead Posted March 18, 2007 Share Posted March 18, 2007 what would this be for? http://www.utahracing.com/Tech/lockup/Lockup.htm http://www.utahracing.com/supras/matthew.html please advise Link to comment Share on other sites More sharing options...
tDR Posted March 18, 2007 Share Posted March 18, 2007 It's really for use with a hi stall torque converter - it lets you stop slippage on motorway runs etc by locking the TC 1:1 direct drive with the autobox. For example, say you have a 4,000 stall TC (like me) and you wanna cruise around 3,000 RPM on the motorway... without the lockup switch the TC would still be slipping and when you accelerate to overtake you'd get even more slippage 'til the point of lockup. This is bad as you're effectively super heating the autobox fluid so the lockup switch lets you induce lockup when you want..... I tend to get into 4th (O/D) on the Mway then straight away engage lockup via my lockup switch. You can tell the difference when you accelerate that there's no slipping going on. HTH, Brian. Link to comment Share on other sites More sharing options...
2jzhead Posted March 18, 2007 Author Share Posted March 18, 2007 Thanks mate, i am contemplating a stage 3/single, but what will i need to do to the auto box Link to comment Share on other sites More sharing options...
tDR Posted March 18, 2007 Share Posted March 18, 2007 Replace it with an uprated boostlogic Toyota based autobox or TH400 autobox conversion or the other option is to do a manual conversion as the 6-Sp Getrag can cope with some serious torque. You'll also need a hi stall torque converter to get the best out of a big single turbo - stall speed you pick depends on what you wanna use the car for and when the turbo is likely to hit full boost - the 'laggier' the turbo, the higher stall speed TC you tend to pick. Cheers, Brian. Link to comment Share on other sites More sharing options...
Guest sindrejl Posted March 19, 2007 Share Posted March 19, 2007 What will happend when you've locked up the system and the box suddenly decides to change gear? nothing? or will the ecu automaticly unlock it for gearing? I've tried to study how the TQ works but not sure what will happend in a scenario like this Link to comment Share on other sites More sharing options...
paul mac Posted March 19, 2007 Share Posted March 19, 2007 i run a BL box with a 3200 stall (T61) and thought i would fit a lock up but haven't felt the need, there is the odd occasion it would be usefull but with a 3200 stall i think you can just about get away without, any higher on the stall and i am sure you would need one Link to comment Share on other sites More sharing options...
ivan Posted March 19, 2007 Share Posted March 19, 2007 Is it worth fitting a lockup switch to the standard autobox or have I got the wrong end of the stick and it's not needed? Link to comment Share on other sites More sharing options...
paul mac Posted March 20, 2007 Share Posted March 20, 2007 Is it worth fitting a lockup switch to the standard autobox or have I got the wrong end of the stick and it's not needed? total waste of time on stock stall torque converter Link to comment Share on other sites More sharing options...
ivan Posted March 20, 2007 Share Posted March 20, 2007 Thought as much, ta. Link to comment Share on other sites More sharing options...
