Lexus oil pressure mod
flukey-lukey
I´m looking to do the Lexus bolt mod. This may sound a stupid question, but when I take off the old bolt will it be pouring oil out? Is there anywhere a good write up how to do this
Also does anyone know will a defi sensor fit in the Lexus bolt?
Thanks
Christian
Thanks
Christian
Short answer = yes:Pling: Drain the oil first then remove the bolt to drill etc. :D
Thanks
Christian
NO, you wont lose any oil - unless you do it with the engine running:p .The job is a lot easier if you remove the oil filter though, so its a good time to get an oil/filter change done.
My Greddy sensor was a perfect fit, so the defi one probably will be too, I think it is only the cheaper sensors that need the bolt re-tapped.
Well after reading a few threads about the lexus is300 union bolt mod for oil pressure guages I decided to get one...
£23 for a sodding bolt!!!!!!! I couldn't believe it!
and £1.06 for the gasket. These were from Pentagon Toyota in Barnsley and won't be in until 27th March. So anyway I paid it after laughing for a while at the parts man... 23 bloody quid.. :( :blink:
I'm not sure what this mod is, but if anyone has the part number let me know and I'll check the price of this expensive bolt from here :)
The part number you need for the mod are,
* 90401-19008 Union Bolt
* 90430-20016 Gasket
* 90301-68005 O-ring (Optional)
When the big bolt is taken off will the whole oil filter assembly come off? Can the bolt be replaced without changing the big o-ring?
If you are careful when removing the bolt, you won't disturb the filter housing, and won't need the O-ring. I've done it several times this way, but space is very limited and it takes some care. Move the power steering resevoir and oil filter before you undo the bolt.
£16 for the bolt, washer and gasket including postage from here if anyone else needs one.
