SMiFFAD Posted March 16, 2007 Share Posted March 16, 2007 Will a K reg import sup require a cat to pass an mot? Looking at one, but it doesnt have the cats. Link to comment Share on other sites More sharing options...
Stonkin Posted March 16, 2007 Share Posted March 16, 2007 presume that would be a 93, didnt the law change in 94? Link to comment Share on other sites More sharing options...
Ian R Posted March 16, 2007 Share Posted March 16, 2007 Someone posted that the VOSA data base had been updated to the effect if it was manufactured with cats it would require them for MOT Link to comment Share on other sites More sharing options...
TrickTT Posted March 16, 2007 Share Posted March 16, 2007 Ian R said: Someone posted that the VOSA data base had been updated to the effect if it was manufactured with cats it would require them for MOT Unless you know a "friendly" MOT centre you will need at least 1 cat in Link to comment Share on other sites More sharing options...
Stonkin Posted March 16, 2007 Share Posted March 16, 2007 My mot place didnt even do the test for emissions as he knew it would fail. Just input his own figures Link to comment Share on other sites More sharing options...
Tom Posted March 16, 2007 Share Posted March 16, 2007 Stonkin said: My mot place didnt even do the test for emissions as he knew it would fail. Just input his own figures and still failed it? Link to comment Share on other sites More sharing options...
absz Posted March 16, 2007 Share Posted March 16, 2007 at the time of test, if the tester fiqures out the engine code ie 2JZGTE and enters it into the computer then it will require a cat test. when i had mine tested the engine code was set to default so no cat test required;) Link to comment Share on other sites More sharing options...
uksupra Posted March 16, 2007 Share Posted March 16, 2007 TrickTT said: Unless you know a "friendly" MOT centre you will need at least 1 cat in is that a visual inspection?? surley a car that passes emissions with or without a cat is a car that passes emissions??? Link to comment Share on other sites More sharing options...
MrAngry Posted March 16, 2007 Share Posted March 16, 2007 The garage I took my car too last week for it's MOT didn't do any emissions tests either. I hadn't mentioned anything to them about not doing it, as it's still got both cats. Link to comment Share on other sites More sharing options...
SMiFFAD Posted March 16, 2007 Author Share Posted March 16, 2007 Hmmm so seems to be a "maybe/maybe not" lol Link to comment Share on other sites More sharing options...
Marty Posted March 16, 2007 Share Posted March 16, 2007 my mot man said aslong as it passes the emissions he wont look for a cat which is now a 3" downpipe just need to run a lean map for the emissions test, between 2-3k revs. Has to be over 0.97 lamba, which 'i think' is about 14.5 afr. Link to comment Share on other sites More sharing options...
SupraJames Posted March 16, 2007 Share Posted March 16, 2007 Mine gets tested as a non-cat equipped car , nice people that they are. Had it tested as a McLaren F1 once according to the emissions computer print out. Link to comment Share on other sites More sharing options...
SMiFFAD Posted March 16, 2007 Author Share Posted March 16, 2007 SupraJames said: Mine gets tested as a non-cat equipped car , nice people that they are. Had it tested as a McLaren F1 once according to the emissions computer print out. you may have to give me the name of your mot man Link to comment Share on other sites More sharing options...
SupraJames Posted March 16, 2007 Share Posted March 16, 2007 SMiFFAD said: you may have to give me the name of your mot man well he was in my good books until last time where they smashed my front bumper lol but its done through a major tuning company based in Oxted Link to comment Share on other sites More sharing options...
G-NEMIE Posted March 16, 2007 Share Posted March 16, 2007 mine also said "if it was manufactured with cats its LIKELY it would require them to pass the MOT" "doesnt matter if its an import, if it drives on our roads its tested by our mot rules". but also said the emmisions test goes off the age of the car. make sure its been for a good hard drive first good luck Link to comment Share on other sites More sharing options...
