Dave Posted March 15, 2007 Share Posted March 15, 2007 just been looking at this kit http://www.boostwerx.com/ the base kit ,ive just a couple of questions 1.would the std n/a ecu be ok 2.would you need a fmic or will it work without one 3.would i need a new manfold 4.would my std fuel pump cope 5.would i need any other electronic wizardy fcd,turbo timer.etc etc 6.with this kit fitted and running on low boost i would be expecting around 300 bhp is this right 7.i presume with this low boost kit your std head gasket would not need to be replaced 8. i would need the oil feed pipe as well and once fitted can it be upgraded as funds allow . is this kit available in the uk ?? cause the dollar/pound exchange rate is good at the mo.but the postage is a lot thanks for your comments guys. Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 15, 2007 Share Posted March 15, 2007 Oh my God, someones found a box of pipe fittings and decided to make a "manifold". Hideous, keep well clear. Link to comment Share on other sites More sharing options...
MARTIN R Posted March 15, 2007 Share Posted March 15, 2007 runs for the hills Link to comment Share on other sites More sharing options...
Ian R Posted March 15, 2007 Share Posted March 15, 2007 Looks like a Blue peter job Link to comment Share on other sites More sharing options...
Dave Posted March 15, 2007 Author Share Posted March 15, 2007 i thought this boostwerx kit was quite reputable so its a load of crap then, whats wrong with it ??????? Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 15, 2007 Share Posted March 15, 2007 Weld-els are not really the thing to make a manifold out of, it's a bit like making a fishing rod from scaffolding pole. Apart from the material choice the gas flow couldn't be worse. Must be something better available. Now if Arnout did his cast iron manifold with an N/A bolt pattern..... Link to comment Share on other sites More sharing options...
G-NEMIE Posted March 15, 2007 Share Posted March 15, 2007 -- http://www.takakaira.com/accessories/nightpager/na_blowoff.jpg -- Link to comment Share on other sites More sharing options...
Daston Posted March 16, 2007 Share Posted March 16, 2007 if you want a cheap NA-T kit check out Autochrome on ebay they sell the Xpower NA-T kits that have been proven time and time again. Link to comment Share on other sites More sharing options...
Daston Posted March 16, 2007 Share Posted March 16, 2007 or even better go to http://www.clubna-t.com and xpower have their own treaders thead on there I think the whole kit is $2000 or there abouts ok shipping will be $400 odd but still a damn good price Link to comment Share on other sites More sharing options...
Dave Posted March 16, 2007 Author Share Posted March 16, 2007 thanks datson as i dont know much about turbos i was just asking for some info and comments which i got along with some sarcasm and a picture of an electric blow off valve sorry mate didnt get that all i want is a basic turbo kit for my n/a that can be upgraded when funds allow will check out the links thanks BTW daston how you enjoying the twins its a nice looking car m8 and the best colour Link to comment Share on other sites More sharing options...
Lebsteif Posted March 16, 2007 Share Posted March 16, 2007 just been looking at this kit http://www.boostwerx.com/ the base kit ,ive just a couple of questions 1.would the std n/a ecu be ok Yes you can keep the stock ecu 2.would you need a fmic or will it work without one Yes you can, but only 1 a 2 psi, not worth it, so go for a FMIC. 3.would i need a new manfold Yes, you can;t keep the stock manifold. 4.would my std fuel pump cope I wouldn;t advise to use a stock pump, go for a proper one. they only cost max 100pounds. 5.would i need any other electronic wizardy fcd,turbo timer.etc etc Yes you need other gizmo's, like a fuelcomputer, widebandmeter, boostmeter. It depends on budget and desired goals. 6.with this kit fitted and running on low boost i would be expecting around 300 bhp is this right Low boost ~7psi will give you aprox 300bhp 7.i presume with this low boost kit your std head gasket would not need to be replaced You don;t need to replace the stock headgasket. 8. i would need the oil feed pipe as well Yes you need the oil kit (oil feed, oil return) and once fitted can it be upgraded as funds allow . is this kit available in the uk ?? cause the dollar/pound exchange rate is good at the mo.but the postage is a lot thanks for your comments guys. The DaveH kit is only available via american webstores like boostwerx.com and http://www.mvpmotorsports.com Keep in mind that all is depending on budget and desired goals, take your time and try to find out as much as you can before you buy something. Here;s a link to get an idea what is involved to setup a basic kit. http://www.supraforums.com/forum/showthread.php?t=265691 Feel free to ask more Link to comment Share on other sites More sharing options...
Dave Posted March 16, 2007 Author Share Posted March 16, 2007 well thanks lebsteif thats what i wanted to know ,according to mr wilson this kit is no good [i think he knows what hes talking about;) ] i will look around for another kit cheers again matey:) Link to comment Share on other sites More sharing options...
RobSheffield Posted March 16, 2007 Share Posted March 16, 2007 BL do an NA-T kit, might be worth checking out Link to comment Share on other sites More sharing options...
Guest Geneb Posted March 16, 2007 Share Posted March 16, 2007 thanks datson as i dont know much about turbos i was just asking for some info and comments which i got along with some sarcasm and a picture of an electric blow off valve sorry mate didnt get that all i want is a basic turbo kit for my n/a that can be upgraded when funds allow will check out the links thanks BTW daston how you enjoying the twins its a nice looking car m8 and the best colour let me know how you get on bud as i've had a quote for £4.5k from Turbofit but that was for a proper job but the upto 4 weeks without a motor put me off Link to comment Share on other sites More sharing options...
hoff Posted March 16, 2007 Share Posted March 16, 2007 What about the Whifbitz kit. Isnt that meant to be pretty good? Link to comment Share on other sites More sharing options...
fishman Posted March 16, 2007 Share Posted March 16, 2007 BL do an NA-T kit, might be worth checking out So do Turbonetics, could be good ?!? Link to comment Share on other sites More sharing options...
Dave Posted March 16, 2007 Author Share Posted March 16, 2007 BL do an NA-T kit, might be worth checking out rob have you got a link m8 and anyone like me who wants the base kit to start should check out this http://www.clubna-t.com lot of good pics and info Link to comment Share on other sites More sharing options...
RobSheffield Posted March 16, 2007 Share Posted March 16, 2007 rob have you got a link m8 http://www.boostlogic.com/parts_supraNA.html I think thats still current, here is hoping Terry will pick up on this and confirm Link to comment Share on other sites More sharing options...
Dave Posted March 16, 2007 Author Share Posted March 16, 2007 if you want a cheap NA-T kit check out Autochrome on ebay they sell the Xpower NA-T kits that have been proven time and time again. have you got a link m8 cause all im getting is polish on a search Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted March 16, 2007 Share Posted March 16, 2007 Think i'll keep my eye on this thread , And to the people thats done a NA-T conversion already - if your wanting to do it yourself what kind of budget can it be done on ?? Link to comment Share on other sites More sharing options...
Guest Terry S Posted March 17, 2007 Share Posted March 17, 2007 As Rob Said Dave, BL do a very nice NA-T kit. PM me for prices. Bromy has had one on his car for ages now if you want to contact him to see what he thinks. Link to comment Share on other sites More sharing options...
Dave Posted March 17, 2007 Author Share Posted March 17, 2007 thanks terry you got a pm Link to comment Share on other sites More sharing options...
bowk1uk Posted March 17, 2007 Share Posted March 17, 2007 Think i'll keep my eye on this thread , And to the people thats done a NA-T conversion already - if your wanting to do it yourself what kind of budget can it be done on ?? did mine myself ,i fitted the xs power kit ,your looking at around £2500-£3000 budget but thats for everything for a good install check out my garrage theres a list there Link to comment Share on other sites More sharing options...
bromy Posted March 17, 2007 Share Posted March 17, 2007 As Rob Said Dave, BL do a very nice NA-T kit. PM me for prices. Bromy has had one on his car for ages now if you want to contact him to see what he thinks. Top quality kit, and as Terry says been on my car for coming up to two years without one problem. Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted March 17, 2007 Share Posted March 17, 2007 What Bhp did you achieve and what does it go like ? I'm getting more and more interested in this conversion , My sup is in good condition ( well i think it is ) and its got 62 tho on the clock is this mileage ok still to be converted or is it impossible to tell really ? Link to comment Share on other sites More sharing options...
