Not making suffiecient boost :'(
islandsupra
Hi Guys,
Really need some help here ... I have a 98 vvti TT, with a blitz catback, mid pipe and dug out the cat converter with no restrictor ring .... from what I see on various posts, I should get about 1.2 bar with this setup ... well maybe not because I would hit the boost cut first. At first, I would hit the boost cut with absolutely no problems from third gear up
However, at present, I am only getting up to .9 bar ... Not certain where to begin with diagnosing this problem ..... I have an HKS SSQV ... the old type (with the screw at the back) fitted .... thinking that this maybe the culprit.
Any advice you can give would be greatly appreciated.
Thanks
Not sure how you'd tell if the IC is leaking. Have you a picture you can post.
The bung that has been put on the turbo pipework oposite the bov, how is it looking?? Is it on tight?? Hasn't mis-shaped or melted in any way??
Thanks ... will check all of these and let you know what I find
