Yellow Hazard Triangle?
Supra_Nish
ok guys think i'm losing it.
A TT i took for a test drive had the triangle hazard light flash in yellow when i floored it - i assumed this was the traction control kicking in?
The TT i have now never seems to flash yellow. Its red when the handbrake is on etc but i never see yellow or any flickering.
Is my traction control working? Any idea's?
The triangle is the master warning light - it lights up red, not yellow. The traction control light is a separate one on the left hand side of the top bit of the dash. If you switch TC off you will see where it is. Warning light when flooring it with no other symptoms is almost certainly low brake fluid - the level goes below the warning level as it sloshes around.
