SupraPL Posted March 13, 2007 Share Posted March 13, 2007 Morning. Could you tell me please, how to replace indicators and sidelights bulbs in facelift Supra? I have got all new bulbs but i can’t swap them. I have no idea how to do this. http://img134.imageshack.us/img134/200/pic0066jx1.th.jpg Regards Tomasz Link to comment Share on other sites More sharing options...
AlanM Posted March 13, 2007 Share Posted March 13, 2007 Quite a few threads on this if you do a search Where abouts you based? Link to comment Share on other sites More sharing options...
M4RK RZ Posted March 13, 2007 Share Posted March 13, 2007 put your hand around the back and twist the 2 round plastic things you can feel. Easy peeeeeezy !!! Link to comment Share on other sites More sharing options...
SupraPL Posted March 13, 2007 Author Share Posted March 13, 2007 Quite a few threads on this if you do a search Where abouts you based? Inverness mate. Not to far from you i think. Regards Tomasz Link to comment Share on other sites More sharing options...
SupraPL Posted March 13, 2007 Author Share Posted March 13, 2007 put your hand around the back and twist the 2 round plastic things you can feel. Easy peeeeeezy !!! ??? Regards Tomasz Link to comment Share on other sites More sharing options...
AlanM Posted March 13, 2007 Share Posted March 13, 2007 Did you work at LifeScan when I was there? Link to comment Share on other sites More sharing options...
SupraPL Posted March 13, 2007 Author Share Posted March 13, 2007 Did you work at LifeScan when I was there? No, am afraid. Regards Tomasz Link to comment Share on other sites More sharing options...
ivan Posted March 13, 2007 Share Posted March 13, 2007 Put your hand in the gap under the lights. Each bulb is held in a twist-off connector. Twist and remove the connectors. Replace the bulbs. Put the connectors back in and twist. Remove hand. Link to comment Share on other sites More sharing options...
SupraPL Posted March 13, 2007 Author Share Posted March 13, 2007 Put your hand in the gap under the lights. Each bulb is held in a twist-off connector. Twist and remove the connectors. Replace the bulbs. Put the connectors back in and twist. Remove hand. Many thanks mate!!! Regards Tomasz Link to comment Share on other sites More sharing options...
M4RK RZ Posted March 13, 2007 Share Posted March 13, 2007 Put your hand in the gap under the lights. Each bulb is held in a twist-off connector. Twist and remove the connectors. Replace the bulbs. Put the connectors back in and twist. Remove hand. Jeasus!! Link to comment Share on other sites More sharing options...
SupraPL Posted March 13, 2007 Author Share Posted March 13, 2007 Jeasus!! I'm like a small child Regards Tomasz Link to comment Share on other sites More sharing options...
SupraPL Posted March 14, 2007 Author Share Posted March 14, 2007 Morning Thanks again guys. Yesterday i replaced sidelight bulbs in 30 sec (both) without problem. Indicator bulbs are easy to replace as well, but i bought Philips Silver Vision PY21W and it looks like i need different bulbs. W21W? Could you look at pictures below please? http://img228.imageshack.us/img228/3281/pic0065gn8.th.jpg http://img137.imageshack.us/img137/9577/pic0068pq1.th.jpg The worse information is that inside lamp is something plastic in orange colour! http://img149.imageshack.us/img149/592/pic0091vz1.th.jpg How to remove that? I want to get clear look! Regards Tomasz Link to comment Share on other sites More sharing options...
M4RK RZ Posted March 14, 2007 Share Posted March 14, 2007 I bought some lights from ebay - they were aftermarket things but with no orange The thing is - even if you take it out you have to pop an orange bulb in - it looks the same anyhow Link to comment Share on other sites More sharing options...
SupraPL Posted March 14, 2007 Author Share Posted March 14, 2007 I bought some lights from ebay - they were aftermarket things but with no orange The thing is - even if you take it out you have to pop an orange bulb in - it looks the same anyhow What type bulbs use this light? Regards Tomasz Link to comment Share on other sites More sharing options...
Guru Posted March 14, 2007 Share Posted March 14, 2007 What type bulbs use this light? Regards Tomasz http://www.funkystyling.co.uk/item_detail.php?prodID=449002189 or speak to Gaz @ Envy as he has them too Link to comment Share on other sites More sharing options...
SupraPL Posted March 14, 2007 Author Share Posted March 14, 2007 http://www.funkystyling.co.uk/item_detail.php?prodID=449002189 or speak to Gaz @ Envy as he has them too Thanks. Regards Tomasz Link to comment Share on other sites More sharing options...
ivan Posted March 14, 2007 Share Posted March 14, 2007 If you've got Silver Vison bulbs then once you replace the unit with a clear one they'll be just right. Link to comment Share on other sites More sharing options...
Guigsy Posted March 14, 2007 Share Posted March 14, 2007 i had silver vision bulbs in my clio i still have the car. i guess there gonna be a different fitting? Link to comment Share on other sites More sharing options...
SupraPL Posted March 19, 2007 Author Share Posted March 19, 2007 Thanks for reply. Regards Tomasz Link to comment Share on other sites More sharing options...
