Brake System - expert/experience needed.
Mike B
I'm experiencing a fairly squishy pedal feel, brakes are good, always work to a good extent, b ut the pedal feel is a lot squishier than the last 2 sups I have had.
Pedal hardens and comperesses much further up the stroke one the brakes have been pumped and when hot (trackday) the pedal engages a lot further down the stroke than normal. this is very different to my last sup which had very positive feel, and never altered with use.
I also feel that the brakes are slightly out of balance, car pulls right, ever so slightly under hard braking...
I have completely changed the fluid today, bled all 4 corners right through, system is exactly the same.
Would a new master cylinder help?
how does the abs system interface with the brakes - could it be a fault in here?
any wisdom welcomed.
Mike, I'm certainly not experienced, but Chris Wilson and Ian or someone were discussing braking instances the other day prior to Donington. A squishy feeling and a greater force required to get the braking up to scratch apparently indicates boiling brake fluid. I'll try and find it.
FOUND IT: half way down matey: http://www.mkivsupra.net/vbb/showthread.php?t=93122&highlight=brake+fluid
Perhaps change the type of fluid you're using mate? :)
Think the stoppers are meant to help reduce/eliminate the movement of the brake servo+master cylinder experienced from the flexing if the bulkhead to which it is all mounted to.
So rather than as you press brake pedal a certain degree of additional travel happens cos your flexing the bulkhead the stopper prevents the master cylinder moving so effort is all transferred to braking and not moving the servo+master cylinder assembly............. sorry if that makes no sense what so ever!:)
Get a Cusco Brake Master Cylinder Stopper fitted to the car, flush the fluid with Motul 5.1 :)
:yeahthat:
I have one of these fitted, they give a noticeable improvement in pedal firmness.
Another alternative is the Carbing tower bar, which has a buit in brace for the brake master cylinder.
http://f10.putfile.com/7/18616374710.jpg
Guest Terry S
Hi Mike,
Think Terry had braided lines fitted already, if not get them done too.
Gaz.
Gaz the car has a Carbing brace with built in Stopper.
Mike that is all a bit weird, It has Project Mu teflon hoses on it, check those, if not, a master cylinder my help.
Did you put 4.1 in the car?
Get someone to press the brakes on and off HARD with engine idling, with car on a ramp. Look to see if the calipers are moving AT ALL on their mounts, or the discs are flexing, if so it could very well be a partly seized caliper. If it had stock rubber lines I'd suggest you squeeze each caliper line off, in turn, with hose clamps, and see if the pedal suddenly gets a lot better. if it did that would ID the offending caliper(s). Braided hose CAN be squashed, but it's not good for it, nor recommended.
Hi Terry,
yes matey - complete fluid change to 4.1, no difference - there is definately something awry somewhere... maybe she is missing your firm hand!
All disks are clean and getting pressure... I guess I may follow chris's disgnostics and then may try a new master, as I don't think that they are that expensive.
Front brakes are new and came off my last car where they were really good, on here they feel totally different!
The reason I asked about the ABS system is that maybe something is wrong in there and this is soaking up the pressure/feel...? stuck caliper would explain the slight yaw under hard braking, but not the pedal feel... right?
