SoundWave Posted March 12, 2007 Share Posted March 12, 2007 That spontaneously fix themselves? Since I have had the car (about 15 months now) I have had 3 different lights start working that didn't to start with. First I noticed that the "put your seatbelt on" light started to work and light up if I hadn't put my seatbelt on yet. Next, one night while driving home I noticed a glare coming from below and looked down to see the lights next to the gear leaver had lit up (I have an auto). These only stayed on for a few seconds initially but on a later journey came back on again and have worked ever since. Lastly, the little hazard-lights warning triangle in the middle of that button has started to work. This one keeps catching my eye as I sometimes forget it's now working and worry there is a red error light showing! So, a car that slowly fixes itself - fantastic! Now if only the green headlight light would work I think I would have a complete set! Link to comment Share on other sites More sharing options...
Kranz Posted March 12, 2007 Share Posted March 12, 2007 I've got some blown bulbs that I wouldn't mind fixing. I'll send them to you!! Link to comment Share on other sites More sharing options...
terribleturner Posted March 12, 2007 Share Posted March 12, 2007 My Imobilser blinking led thingie stopped flashing last week. I took the dash apart, checked the cables, looked at the light and it was working. So slapped it all together again. A few days later i look and the bloody thing has stopped again. Ended up rewiring the thing. Fingers crossed it has been fine ....... so far. Link to comment Share on other sites More sharing options...
edge Posted March 12, 2007 Share Posted March 12, 2007 Not quite the same but My oil/abs lights didnt work. Thought it was the bulbs but further investigation proved wrong. Then the next sign was a broken wire as they flikered on/off when i held the connecter. Turned out to be dry joints on the track where the connector is on the light unit. Joints remade and perfect ever after. Link to comment Share on other sites More sharing options...
RobCowley Posted March 12, 2007 Share Posted March 12, 2007 My old MR2 was the same, with the lights behind the speedo and rev counter. Don't think i ever had them all working at the same time The Green headlight light..........we have one of those?? Link to comment Share on other sites More sharing options...
juanchan Posted March 12, 2007 Share Posted March 12, 2007 The Green headlight light..........we have one of those?? I was thinking that! Is there a blue light for the full beam lights? I'm not aware of having one myself... I also didn't know that the warning triangle has an LED behind it. I'll have to double check to see if that's working now! Link to comment Share on other sites More sharing options...
RobCowley Posted March 12, 2007 Share Posted March 12, 2007 Yeah the hazard light switch is lit up when you turn the lights on...and I'm pretty sure there is a light on the dash for full beam Link to comment Share on other sites More sharing options...
juanchan Posted March 12, 2007 Share Posted March 12, 2007 Yeah the hazard light switch is lit up when you turn the lights on...and I'm pretty sure there is a light on the dash for full beam I need to get digging round the fuse box then methinks! The LED on my Clifford stopped a couple of weeks back too Link to comment Share on other sites More sharing options...
Sheefa Posted March 12, 2007 Share Posted March 12, 2007 There is a light icon for driving lights/or full beam on mine - not sure as they've never lit up. I thought it might be an MOT requirement though! Hopefully will fix it sometime soon. Link to comment Share on other sites More sharing options...
juanchan Posted March 12, 2007 Share Posted March 12, 2007 There is a light icon for driving lights/or full beam on mine. I thought it might be an MOT requirement though! I'll have a look into that then. The only interior light I'm aware of that's included in the MOT is the ABS light which works fine (so far...) Link to comment Share on other sites More sharing options...
Kranz Posted March 13, 2007 Share Posted March 13, 2007 I'll have a look into that then. The only interior light I'm aware of that's included in the MOT is the ABS light which works fine (so far...) Indicator warning lights have to work for MOT Link to comment Share on other sites More sharing options...
SoundWave Posted March 13, 2007 Author Share Posted March 13, 2007 Well i'm only guessing there should be a green headlights-on light. I do have the usual blue one for full beam. Link to comment Share on other sites More sharing options...
