Guest MOFFETT Posted March 12, 2007 Share Posted March 12, 2007 On a standard engined jap spec twin turbo maual. What sort of money(approx) will it cost to get 380-400bhp and will that sort of power be reliable? cheers Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted March 12, 2007 Share Posted March 12, 2007 exhaust (£300 - 600) double decat (£300) restrictor ring (£30) new colder spark plugs (£50) FCD (£70) additional you will prob want; Walbro pump (£80) theres a thread ill do a search and yes the 400bhp is reliable I use mine every day. Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted March 12, 2007 Share Posted March 12, 2007 got it... http://www.mkivsupra.net/vbb/showthread.php?t=94705 Quote Link to comment Share on other sites More sharing options...
Lukeyboy2k Posted March 12, 2007 Share Posted March 12, 2007 exhaust (£300 - 600) double decat (£300) restrictor ring (£30) new colder spark plugs (£50) FCD (£70) additional you will prob want; Walbro pump (£80) Obviously different garages, differing cars (unmovable first cats etc) would make the cost vary, but what would be a sensible amount of labour time a garage would charge to fit all of the above? Quote Link to comment Share on other sites More sharing options...
cashpoint Posted March 12, 2007 Share Posted March 12, 2007 Your'll need to increasse the boost to, on the cheap £20 for bleed valve but you may adjust it to much and have to replace far far more expensive parts, so electronic boost controllers start at £140, if your std SMIC is old it's best to either get a new SMIC(£250) or a FMIC(£300) Quote Link to comment Share on other sites More sharing options...
ry4n Posted March 12, 2007 Share Posted March 12, 2007 exhaust (£300 - 600) double decat (£300) restrictor ring (£30) new colder spark plugs (£50) FCD (£70) additional you will prob want; Walbro pump (£80) The look on your face when you put your foot down (priceless!) Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted March 12, 2007 Share Posted March 12, 2007 Your'll need to increasse the boost to, on the cheap £20 for bleed valve but you may adjust it to much and have to replace far far more expensive parts you wont need to adjust the boost that is what the restrictor ring is there to stop, just get a 1.1 bar restrictor ring and in colder wather you'll boost closer to 1.2bar anyway. So you dont need to spend loads of money at first for that initial power increase. Check the condition of your SMIC like cashpoint says though. Quote Link to comment Share on other sites More sharing options...
Guest MOFFETT Posted March 12, 2007 Share Posted March 12, 2007 So £1200 - £1350 would be plenty then...Good bang for the buck then. cheers for the quick replys lads. Quote Link to comment Share on other sites More sharing options...
Homer Posted March 12, 2007 Share Posted March 12, 2007 So £1200 - £1350 would be plenty then...Good bang for the buck then. cheers for the quick replys lads. Its great bang for buck and completly transforms the car IMO. Also click here for full details: bpu Quote Link to comment Share on other sites More sharing options...
tbourner Posted March 12, 2007 Share Posted March 12, 2007 IMO this post by Nic is one of the best regarding BPU upgrades: http://www.mkivsupra.net/vbb/showpost.php?p=1301261&postcount=2 If you're a perfectionist that is! Quote Link to comment Share on other sites More sharing options...
Nic Posted March 12, 2007 Share Posted March 12, 2007 exhaust (£300 - 600) double decat (£300) restrictor ring (£30) new colder spark plugs (£50) FCD (£70) ...and a boost gauge to monitor things (£100+), an EGT (£130+)or AFR gauge (£200+) would also be a good idea. Quote Link to comment Share on other sites More sharing options...
Chewie Posted March 12, 2007 Share Posted March 12, 2007 exhaust (£300 - 600) double decat (£300) restrictor ring (£30) new colder spark plugs (£50) FCD (£70) additional you will prob want; Walbro pump (£80) theres a thread ill do a search and yes the 400bhp is reliable I use mine every day. Last week I've been in contact with Chris Wilson on exactly this subject. With the exception of the pump this is more or less what he recommends. As somebody has already said the restrictor ring will limit boost to 1.2 bar. He recommend HKS Hyper Silencer or Trust Power Extreme 2 exhaust. Also check out your intercooler condition. Quote Link to comment Share on other sites More sharing options...
