Brake pedal bitting low
Ryan.G
My uk brakes on my j-spec supra and the brakes dont really bite to really low down on the pedal play. Now today i bled the whole system and checked all the pads had enough meat on them and i still have the same problem. Some air did come out and i thought that would solve the problem.
Has 5.1 fluid and braided lines
Im stumped is there any way to adjust pedal to make bite earlier and reduce play
Thanks
One thing i just released is that i have traction control and that that needs bleeding any tips on how to do that as searched but says you need toyota tool in pdf's
Whats this?
Don't know. I take it that you have a UK spec then?
It won't be the trac control as you have a Jspec and it's only connected to the brakes on UK/US. Have you got the anti-squeel shims on the back of the pads? If so take them off and see if that improves things, they can cause a bit of sponginess. Plus check for leaks and bleed 'em again I guess.
See if the brake lights come on when you initially press the pedal..
Mine seemed to only bite quite low down, however I noticed the brake lights didnt come on untill the pedal got quite low down, so ive put it down to the pedal requiring adjusting.
I havnt got round to doing it yet though, so not sure if it works!
