Best Place to Source Front Lip?
Guest Enola Gay
Guest Enola Gay
It is def' missing on car I just bought. Seem to remember someone saying I needed aluminum parts as well but cannot find thread now. Undertray is there. So my question is - where is best place to source the Lip which goes on front end and is lowest part of the car, is there a recommended Breaker? Also do I need any other parts in order to fit Lip or to go with it please? (not got active front spoiler)
Heres the thread you cant find
http://www.mkivsupra.net/vbb/showthread.php?t=101719
If the undertray is still on the car, all you need is the rubber lip itself and the upper and lower aluminium backing plates and the nuts (the upper backing plates already have the bolts attached).
You can buy the lip and backing plates new from Toyota but they are expensive...a breakers a better bet as long as long as the backing plates / bolts are in good nick. Its a pain to fit (the upper backing plates have to be fitted from 'inside' the bumper) and I found it easier to take the undertray partially off to gain better access....if you fancied an aftermarket lip, you can use the same backing plates and the fitting times the same.
