Touch-up paint for a J-Spec?
martynb
halfords do a paint matching service but personally I just went to the nearest paintshop I could find and bought a spray can of paint and one of lacquer and then spray into a small container and paint on with a model brush (00)
Originally posted by martynb
I didn't think this would be a problem but I've just called my local Toyota Centre and they tell me that 6N0 which is the gunmetal silver doesn't come up on their computer?
Anyone know where I could source some please?
Cheers
Well I sourced Quicksilver 1B9 from my local Toyota dealer.
It all depends on who you get, and whether they can be arsed with imports.
Mine came from Hawkins Toyota, Epsom 020 8224 3030
HTH
Er - I'm a bit tired after a long day but are you suggesting that I can get an aerosol of a specific toyota colour at any paint shop?
HTH
But I think the problem is that 1B9 is a colour used in the UK whereas 6N0 isn't?
The person I spoke to was very helpful and spent quite a while
trying to get the toyota database to recognise it, but it simply wouldn't have it.
I only want to do a couple of stonechips...
Best way if you can not get the colour code or can not find some one to mix that code , if you chip a tiny piece of paint off from under the bumper were it is out of sight take this to your local paint dealer , near me is "total concept" paint's unsure if this is uk wide dealer , but alot of places have a machine that will analyze the paint and then mix paint for you, I have done this load's of times .
ps the paint you get from halford's is not 2 pac paint it's cellouse , and also you will find it very hard to blend the paint in and get a good finish with a can.
If you need any help pm me
"my other skill is a automotive sprayer"
yes I've got 1A1 - Bronze and they matched it beautifully, as I said I just spray some into a container and paint it on with a small brush (like the ones used for model painting) and then once that has dried do the same with the lacquer - certainly the best touch up match I've ever come across (but you do need to be quick with the lacquer as it starts to solidify very quickly so do it in very small batches :)
