DannyW Posted March 10, 2007 Share Posted March 10, 2007 Anyone know how much a stock clutch replacement would cost for a J-spec 6 speed? Quote Link to comment Share on other sites More sharing options...
steb9780 Posted March 10, 2007 Share Posted March 10, 2007 Anyone know how much a stock clutch replacement would cost for a J-spec 6 speed? I think the clutch itself is usually around the £400 mark, and labour is around £150-200. But people seem to say it's worth changing the flywheel too. Quote Link to comment Share on other sites More sharing options...
Guest Power-GT Posted March 10, 2007 Share Posted March 10, 2007 You can get a full kit for about £210 - £250 ish i think from Blue Print (No flywheel included in that price ) And the plates are usually Exedy so they are not too bad as a 'stock replacment' item. Quote Link to comment Share on other sites More sharing options...
steb9780 Posted March 10, 2007 Share Posted March 10, 2007 You can get a full kit for about £210 - £250 ish i think from Blue Print (No flywheel included in that price ) And the plates are usually Exedy so they are not too bad as a 'stock replacment' item. Ah right. I was going off some of the prices I'd seen from some of the traders here. Personally I have just had a Chris Wilson modified stock clutch fitted, new flywheel, and new bearings but this is a bit more expensive. Quote Link to comment Share on other sites More sharing options...
Daston Posted March 10, 2007 Share Posted March 10, 2007 I got one off a US company on ebay for not that much and it worked a dream I will try to find out who it was Quote Link to comment Share on other sites More sharing options...
DannyW Posted March 10, 2007 Author Share Posted March 10, 2007 Thanks Quote Link to comment Share on other sites More sharing options...
Daston Posted March 10, 2007 Share Posted March 10, 2007 Heres a link to a cluch for an SZ They do them for TT's as well http://cgi.ebay.com/ebaymotors/TOYOTA-SUPRA-LEXUS-SC300-3-0-L-NEW-OEM-Clutch-Kit_W0QQcmdZViewItemQQcategoryZ33730QQihZ005QQitemZ150097330143QQrdZ1QQsspagenameZWD2V Quote Link to comment Share on other sites More sharing options...
DannyW Posted March 10, 2007 Author Share Posted March 10, 2007 Thanks for that, did you fit it yourself? if not then what did you get charged for it? cheers. Quote Link to comment Share on other sites More sharing options...
Daston Posted March 10, 2007 Share Posted March 10, 2007 Cost me £80 at a local garage. Quote Link to comment Share on other sites More sharing options...
Ric Posted March 10, 2007 Share Posted March 10, 2007 80quid to fit a clutch Quote Link to comment Share on other sites More sharing options...
Daston Posted March 10, 2007 Share Posted March 10, 2007 yep they put my RS*R on at the same time. However they are real good friends of my Dad's so not too sure if I got a mate rate Quote Link to comment Share on other sites More sharing options...
Rayman Posted March 10, 2007 Share Posted March 10, 2007 Thats unlucky danny, is it slipping badly? Quote Link to comment Share on other sites More sharing options...
DannyW Posted March 10, 2007 Author Share Posted March 10, 2007 When i get to about 2500rpm in 5th or 6th gear with the go pedal pressed all the way down, the revs seem to jump up above 3200rpm like clutch slip, but they then drop a bit then rise again as normal right to the red line. I don't know if it is the clutch or not, i can't smell it burning and it only does it at low revs, if it was the clutch i would have thought it would slip higher up at the peak power revs? But what else could it be? Quote Link to comment Share on other sites More sharing options...
Daston Posted March 10, 2007 Share Posted March 10, 2007 sounds like the clutch my SZ would slip when ever I put my foot down hard as long as I was smooth it was ok Quote Link to comment Share on other sites More sharing options...
DannyW Posted March 10, 2007 Author Share Posted March 10, 2007 Ive had clutches go before on other cars and they always slipped higher up the rev range, mines only doing it low down. The other thing is that the bite point on the clutch is quite high up too. Any ideas? Quote Link to comment Share on other sites More sharing options...
MrHanky Posted March 10, 2007 Share Posted March 10, 2007 When i get to about 2500rpm in 5th or 6th gear with the go pedal pressed all the way down, the revs seem to jump up above 3200rpm like clutch slip, but they then drop a bit then rise again as normal right to the red line. I don't know if it is the clutch or not, i can't smell it burning and it only does it at low revs, if it was the clutch i would have thought it would slip higher up at the peak power revs? But what else could it be? Danny, sounds like its doing exactly what mine was doing. I changed the clutch and flywheel and everything is fine now. Mark Quote Link to comment Share on other sites More sharing options...
DannyW Posted March 10, 2007 Author Share Posted March 10, 2007 Danny, sounds like its doing exactly what mine was doing. I changed the clutch and flywheel and everything is fine now. Mark Bugger Quote Link to comment Share on other sites More sharing options...
MrHanky Posted March 10, 2007 Share Posted March 10, 2007 Ive had clutches go before on other cars and they always slipped higher up the rev range, mines only doing it low down. The other thing is that the bite point on the clutch is quite high up too. Any ideas? I was thinking exactly the same when mine went wrong (with regards to when it slips), but it did turn out to be clutch. I ordered a RPS clutch and flywheel from MVP and got them at a good price and in very quick time. They do recommend that you change the flywheel when doing the clutch, if you do this and think about the RPS flywheel, be warned that it does make your car sound clunky (due to the lightness of it). It drives great but does make a bit of an agricultural sound when pulling off. Quote Link to comment Share on other sites More sharing options...
DannyW Posted March 10, 2007 Author Share Posted March 10, 2007 I'll just stick with stock i think, i have no plans for more power and i can't justify the extra cost, i'll have a ring round on Monday and see if i can find somewhere that will do it. Quote Link to comment Share on other sites More sharing options...
8800 Posted March 10, 2007 Share Posted March 10, 2007 Heres a link to a cluch for an SZ They do them for TT's as well http://cgi.ebay.com/ebaymotors/TOYOTA-SUPRA-LEXUS-SC300-3-0-L-NEW-OEM-Clutch-Kit_W0QQcmdZViewItemQQcategoryZ33730QQihZ005QQitemZ150097330143QQrdZ1QQsspagenameZWD2V hi , how long have u had that kit ? Quote Link to comment Share on other sites More sharing options...
Daston Posted March 10, 2007 Share Posted March 10, 2007 I had it on the car for over a year (dont own the car anymore) it was exacly like the oem one though and had no problems with it at all Quote Link to comment Share on other sites More sharing options...
8800 Posted March 10, 2007 Share Posted March 10, 2007 thanks for the reply Daston, only need these to last 1 year so these are quite suit my needs -- only $80 for the NA clutch but $116 for p&p lol still cheap tho Quote Link to comment Share on other sites More sharing options...
DannyW Posted March 11, 2007 Author Share Posted March 11, 2007 Just took the car for a run and the clutch is slipping worse now. I feel like crying, only had the car a week, i drive like a granny most of the time and the first time i open it up the clutch slips. Gutted Quote Link to comment Share on other sites More sharing options...
colsoop Posted March 11, 2007 Share Posted March 11, 2007 Thge prices i have are a few years old but they are as follows: Clutch cover assembly £119.95 Clutch release bearing £37.33 Clutch plate £78.33 Flywheel £258.28 Flywheel bolts £60 Labour to fit was £150 Those prices were july 04 and do not include vat or discounts Quote Link to comment Share on other sites More sharing options...
steb9780 Posted March 11, 2007 Share Posted March 11, 2007 Just took the car for a run and the clutch is slipping worse now. I feel like crying, only had the car a week, i drive like a granny most of the time and the first time i open it up the clutch slips. Gutted I know how you feel mate. I'd only had mine for 2 weeks before mine started slipping. Quote Link to comment Share on other sites More sharing options...
