Guest Enola Gay Posted March 10, 2007 Share Posted March 10, 2007 Just got car and want to take the wheels off. No tool/socket etc with car (import) to take off what looks like a cover secured with a 65mm alloy(?) nut - see pic. Is this a cover and where can I get 'tool' to remove? I presume underneath is normal 5 bolt set up? Quote Link to comment Share on other sites More sharing options...
AlanM Posted March 10, 2007 Share Posted March 10, 2007 Looks like the TSW size, if you can't get a spanner (they were plastic and useless anyway) just knock the nut with a block of wood and a hammer Quote Link to comment Share on other sites More sharing options...
Guest Enola Gay Posted March 10, 2007 Share Posted March 10, 2007 It does sat TSW in the middle. Is it normal five bolt underneath? Quote Link to comment Share on other sites More sharing options...
AlanM Posted March 10, 2007 Share Posted March 10, 2007 Yep, you will find as soon as you move the nut a mm or 2 it will be loose Quote Link to comment Share on other sites More sharing options...
Guest Enola Gay Posted March 10, 2007 Share Posted March 10, 2007 Just tried wood and hammer - its not having it. Looks like drive to my mate who is an engineer and likely to have a socket or something. Thanks for info... Quote Link to comment Share on other sites More sharing options...
AlanM Posted March 10, 2007 Share Posted March 10, 2007 If you don't get it I will go and search garage as I had a couple of them at one stage Quote Link to comment Share on other sites More sharing options...
Guest NINJYA Posted March 10, 2007 Share Posted March 10, 2007 i had this problem with my import, managed to remove using a heatgun and hammer - with force. Quote Link to comment Share on other sites More sharing options...
garethr Posted March 10, 2007 Share Posted March 10, 2007 Just measured a TSW spanner. It's 74mm across the flats. Quote Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted March 10, 2007 Share Posted March 10, 2007 Thats a big ass spanner . Why did tsw do this ? its a crap idea Quote Link to comment Share on other sites More sharing options...
Ibrar Jabbar Posted March 10, 2007 Share Posted March 10, 2007 Use a pipe wrench to undo it, make sure to cover the cap nut with with a few layers of masking tape first so you don't scratch it, it should undo with a sharp shock. Quote Link to comment Share on other sites More sharing options...
