what would you do???
Daston
Hmm what would you do with £2k to spend on the car???
I am thinking Border Racing II kit as I have always liked it but that comes in at just over £2k with out the rear spoiler and then I have fitting on top................
Dave, what's the spec of you TT? You need to update your garage ;)
I'm sure I can find something else to spend your money on :p
good plan
I have just found these babys when clearing out the spare room
Are they ok to use they could do with a clean but there apares to be some rust on the actual disk.
if they are ok will just need UK calipers
how much would it cost to fit Gaz? Is there a lot involved in setting them up? Also would you recomend a FMIC as well?
We typically charge £700 to fit. Its normally around 20 hours labour.
I'd recommend an FMIC yep. If its just hybrids you want a 2 row (Greddy or HKS) will suffice or my personal favourite is a Blitz LM V-spec.
Gaz.
