Removing headlining
RobSheffield
Interior light, just pop the clear cover off, there are two screws inside, from memory, behind the bulbs.
The headling just clips in, I think it is held at the sides by the various balck plastic trims, the main fixing being the interior light surround. Take off the two a-pillar covers, they just pull off as they are held by locating lugs and spring clips.
That'll give you enough lee-way to pull down the head lining to do what you want to do. I found it enough to install little green LED headlining lights so I get a light green glow at night.
