manual conversion
Guest cashie2000
Guest cashie2000
hi im new to this site. ive got a 1994 uk auto supra tt. i want to put a manual gear box in it. ive been told i can get all the parts for about £500.i have a rough idea what i need but can anyone tell me exactly what i need to do it? also i spoke to my mechanic who said it shouldnt be to much of a problem to fit as long as all the mounts are there? does anyone know if i need to do any major modifications to get it all to fit?
Guest cashie2000
my mate bought all the parts to do it from combelack breakers for £300 but that was a 5speed box and with out the ecu which i thought was quite a bargin.
5spd will work, but its not as strong as the 6spd. Also, how about all the other stuff - the list is pretty huge.
'Jezzybabes' does a 6spd conversion kit for around £2300, though I don;t think he has any in stock (waiting for some more write offs!)
Guest cashie2000
i know that the manuals tts come as 6 speed but he could only get hold of a na box.he told me that it would be best to get a 6 speed but a 5 speed would still go in. i aint no mechanic so aint to sure but he definately had it runnin with a 5speed.
The 5 speed is probably from the na or a mk3. you still need a manual diff, gearbox, clutch, flywheel, master/slave cylinders. doubt you would get everything for £500 mate.
Guest cashie2000
he did say it wasnt going to be as strong but as i only have a pretty much standard engine i would have thought it would be fine.
Guest cashie2000
im just going off waat i was told. seems to me he got a bargin after reading this. i just wanted a list of what i needed really so i could ring around and see what sort of prices i was getting.my mrs dad is a mechanic so i shouldnt coet me to much to get it fitted its just finding the parts for the right price
It would be a bargain if they were the right (6 speed) parts. Seems like they aren't though.
So now you've got the list how does it compare to what your guy has bought?
Any problems running the Jspec LSD auto diff??? And I'm after a kit for £500 if anyone wants to sell me it ;)
You can't the prop lenghts are different.
With a 5spd, the 5spd components are going to be needed (diff, driveshaft, prop, etc), it's not designed for TT power. It will work, sure, but it's not going to be as strong.
I'd be amazed if he can do it for that price. The NA parts maybe, but even the cheapest garages here will charge £600+ for fitting alone.
Guest cashie2000
well i aint still to clear on what i do need as you seem to be talking about 6speed parts and im not sure if its differnt parts for a 5 speed.he didnt give me a full list of what he got. sure he mentioned changing the prop tho?he obviosly got the right parts because he had it dunning. whether it was strong and efficient enough i dont know.
Here you go:
Part Number Qty Part name
90363-12002 1 BEARING FOR INPUT SHAFT)
31250-14190 1 DISC ASSY, CLUTCH
96152-00500 1 RING, SNAP (FOR CLUTCH RELEASE HUB)
90903-63001 1 BEARING , BALL (FOR CLUTCH RELEASE HUB)
31210-14170 1 COVER ASSY, CLUTCH
90119-08026 6 STD PART
90560-79001 1 WASHER, PLATE (FOR CLUTCH RELEASE BEARING)
90206-12006 1 WASHER, WAVE (FOR CLUTCH RELEASE BEARING)
90520-75001 1 RING, SHAFT SNAP (FOR CLUTCH RELEASE BEARING)
31264-14060 1 SPRING, CLUTCH THRUST CONE
31231-14050 1 HUB, CLUTCH RELEASE BEARING
31204-14060 1 FORK SUB ASSY, CLUTCH RELEASE
90119-10054 2 STD PART
31236-14030 1 SUPPORT, RELEASE FORK
55107-14120 SUPPORT SUB-ASSY, CLUTCH PEDAL
90541-06036 2 CUSHION, NO.1 (FOR CLUTCH PEDAL)
90386-13015 BUSH (FOR CLUTCH PEDAL SPRING SEAT UPPER)
31353-14010 HOLDER, CLUTCH PEDAL SPRING
96160-00600 STD PART
90949-03012 STD PART
90949-03010 SPRING (FOR CLUTCH PEDAL)
90386-13015 2 BUSH (FOR CLUTCH PEDAL)
90101-10015 SHAFT, CLUTCH PEDAL
90387-10003 COLLAR, CLUTCH PEDAL SHAFT
90240-08006 PIN, W/HOLW (FOR CLUTCH MASTER CYLINDER PUSH ROD CLEVIS)
90206-08001 STD PART
90386-08033 BUSH (FOR CLUTCH MASTER CYLINDER PUSH ROD CLEVIS)
90386-05017 STD PART
94512-01000 STD PART
94110-51000 STD PART
90468-16142 STD PART
31301-14110 PEDAL SUB-ASSY, CLUTCH
31321-14020 PAD, CLUTCH PEDAL
31410-24050 1 CYLINDER ASSY, CLUTCH MASTER
93385-16010 STD PART
31464-24020 1 INSULATOR, CLUTCH MASTER CYLINDER HEAT
31470-14060 1 CYLINDER ASSY, CLUTCH RELEASE
91611-60825 BOLT (FOR CLUTCH RELEASE CYLINDER SETTING)
31482-14050 TUBE, CLUTCH RELEASE CYLINDER TO FLEXIBLE HOSE
96991-10080 2 STD PART
31484-24010 1 BRACKET, FLEXIBLE HOSE, NO.2 (FOR CLUTCH)
90119-06406 STD PART
31481-14240 TUBE, CLUTCH MASTER CYLINDER TO FLEXIBLE HOSE
96816-50335 HOSE, CLUTCH, NO.1
58280-14080 1 BOOT, SHIFT AND SELECT LEVER, NO.1
90159-60310 STD PART
58261-14010 1 COVER, TRANSMISSION
83242-1U270 1 TACHOMETER ASSY, ENGINE
83194-87501 STD PART
58804-14040 PANEL SUB-ASSY, CONSOLE UPPER
33030-0W180 1 TRANSMISSION UNIT ASSY, MANUAL
33504-14130 1 KNOB SUB-ASSY, SHIFT LEVER (FOR FLOOR SHIFT)
33555-14110 1 BOOT, SHIFT & SELECT LEVER NO.2
93381-16012 STD PART
90179-08079 2 STD PART
33555-14100 1 BOOT, SHIFT & SELECT LEVER, NO.3
90301-11015 4 RING, O (FOR SHIFT LEVER)
90387-08134 2 COLLAR (FOR FLOOR SHIFT)
33530-14442 1 LEVER ASSY, SHIFT (FOR FLOOR SHIFT)
90105-08200 2 STD PART
33057-14010 BRACKET, CONTROL SHAFT, LOWER NO.2
33556-14050 SEAT, TRANSMISSION SHIFT LEVER BALL
90105-08076 STD PART
33546-22020 BUSH, NO.2 (FOR CONTROL SHIFT LEVER, RETAINER)
91651-60835 2 STD PART
90179-08233 STD PART
33570-14070 RETAINER, CONTROL SHIFT LEVER (FOR FLOOR SHIFT)
33513-22030 YOKE, CONTROL SHAFT, NO.1
33531-14010 BOOT, DUST (FOR CONTROL SHIFT LEVER)
33511-14030 SHAFT, CONTROL (FOR FLOOR SHIFT)
90179-11017 NUT, NO.2 (FOR PROPELLER SHAFT & DIFFERENTIAL SETTING)
90201-11013 WASHER, NO.2 (FOR PROPELLER SHAFT & DIFFERENTIAL SETTING)
37100-14810 SHAFT ASSY, PROPELLER W/CENTER BEARING
90119-10217 BOLT, NO.1 (FOR CENTER SUPPORT BEARING)
90201-10123 WASHER, NO.2 (FOR CENTER SUPPORT BEARING
90105-12265 BOLT, NO.1 (FOR PROPELLER SHAFT & DIFFERENTIAL SETTING)
90179-12128 NUT, NO.1 (FOR PROPELLER SHAFT & DIFFERENTIAL SETTING)
90560-12059 WASHER, NO.1 (FOR PROPELLER SHAFT & DIFFERENTIAL SETTING)
See also:
http://www.mkivsupra.net/vbb/showthread.php?t=16773
http://www.mkivsupra.net/vbb/showthread.php?t=91861
Guest cashie2000
im not struggling. i know its going to be weaker but how much weaker is what i need to find out. as i hardly every cane my car i would have thought it would be strong enough.but this is what im trying to find out. obviosly if i can get a 5speed for half the price and it will handle what i need it to that is what i will do. i only have a list of parts for 6 speed
TBH I'd be more inclined to lengthen the front propshaft from the auto to fit the manual box. It needs to be about 50mm longer. This way the auto rear prop, diff and left driveshaft can be used instead of sourcing 6 speed ones.
There is nothing wrong with running a standard supra(or even lightly modified) on the W58 5 speed. The 6th gear is more a top end thing anyway. When people talk about the 'strength' of a box, they are usually talking about how much abuse it will take. You can kill any box if you drive like a tit! Slamming gears and abusive downshifts will destroy a V160 as well as an R154 or W58. Its just a matter of time.
