full service?
Al_Lilley
engine Oil, Diff oil, Gearbox/Autobox oil, Air filter, Fuel filter, Brake fluid, Clutch fluid (If you have a clutch) Spark Plugs, (Distributor cap, rotor Arm, if NA) Cam Belt, Aux Belt, Coolant
Complete car check, Suspension chassis etc etc
Im sure ive missed something :)
nah ive kept the stock box and got my self a new panel filter...just lookin into what belts to get..prob go with power enterprise...anyone got any other suggestions? and lookin into spark plugs...would like some good spark plugs...just running over stock setup..basic aftermarket exhaust upgrade for the na etc
You could get PE belts, however on a NA its a bit of an overkill, The stock belts are more than good enough.... A waste of money IMO... :)
Youde be better to spend the extra on a new fuel pump, Walbro etc.... so that everything is working to its optimum...
Mines about to have a full service I forgot about the Distributor cap, and rotor arm! Thanks.
Guest fordyce
So how much roughly for the full service including the suspension? Mines banging, presumably the bolts are lose but would rather getting checked properly.
I'd also like to know how much i should be paying for a full service. I've been quoted around £430 by Toyota for a 'C' service and i'm considering just using them. I would probably rather go elsewhere but there aren't any specialist garages in the area that i would trust with my car.
So what power you want to run? I mean a BPU TT can run 400hp and these can run easily on the standard cambelt...
If you NA-T it, to run bigger hp you willhave to chage the head gasket, so the new belt will have to come off anyway... Once off Ide want to replace it with new...
Go PE when if you go NA-T
Thats seems a lot! I guess the discs were expensive though?
Yes, they were around £400 for disks and pads all round. Plus, the guy I use is probably the most reputable and technically proficient on the forum, and his rates are very, very reasonable ;)
  • 7 months later...
